4Wheel Drive not working any ideas???
Discussion in '1983-2005 S-Series models' started by speedyvision917, Aug 8, 2004.
  1. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    my dad has a 1993 Chevy S-10 Blazer, its got the pushbutton to engage the 4 wheel drive but it wont engage it, what do you think it could be? i think it might be a fuse or theres this vacuum like plug that engages the 4wheel drive by gettin sucked into the transfer case im pretty sure, if it is are those easily replaced? or what else could it be /forums/images/graemlins/thinking.gif
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if its vac operated then check you lines, it might be electric so check the moter
  3. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    sounds like the acct motor is bad mine did the same thing
  4. speedyvision917
    May 5, 2004
    472
    CT
    how can i check that? /forums/images/graemlins/thinking.gif
  5. globaljames
    globaljames Registered Member
    Apr 2, 2004
    52
    AZ. Scottsdale
    On my s-10, there is an vacuum actuator UNDER THE BATTERY TRAY...
    The battery acid destroyed the seal...
    It was a very easy fix...
    Hope this helps...
