4wheel drive won't work?
Discussion in '1992-Present Chevy & GMC models' started by lgk5, Nov 28, 2004.
  1. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    4wheel drive won\'t work?
    you can shift it into 4x4 the drive shaft turns
    but not the wheeels?????
    any help would be great, /forums/images/graemlins/truck.gif 88 1500 ifs /forums/images/graemlins/truck.gif
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Re: 4wheel drive won\'t work?
    Probably the actuator in the front differential.
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    IIRC, the older ones had a lot to be desired in their operation. Most owners changed them to a manual acutator, such as the 4x4 posi lock. (Jeep guys deal with that crap too). It replaces the problomatic vacuum or thermal system with an in cab control.
    IIRC, the drive shafts always turn.
  4. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    the front shaft shouldn't turn unless its in 4wd. my guess would be a bad actuator as well, unless by "the front wheels arent turning" you mean theyre seized up solid, in which case you may want to just shoot it and put it out of its misery. /forums/images/graemlins/dunno.gif
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Put it in 4wd and either touch the actuator (it should get hot), or take it out and see if it works.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The early IFS trucks have an actuator that engages when an electrical heater inside causes a gas to expand. This pushes out on the shaft and engages the front diff. When they get old (and some of the gas has leaked out) then they don't work well, especially when it's cold outside. /forums/images/graemlins/frown.gif GM sells a replacement that uses an electrical motor instead of the heated gas. IIRC, it's around $100, if you can get the "good buddy" price at the parts counter.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Just to add a little to this...(and a good parts counter guy should know) If you get the new style electric motor actuator, you also need to get a little wiring harness to go with the new style motor.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The ~ $100 price tag includes the pigtail that you need to buy to plug it all together. :thumb:
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    It's been a while, but I think mine came seperately.. :( But either way, I have a friend that works at the delaership and I didn't pay anything close to retail.. :thumb:
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it comes as 2 different part numbers, in 2 different packages. As I recall, it's about $140 retail for both. My price at a local shop is around $100. You only need the pigtail the first time. If you have to replace the motor later, you can buy just the motor. :cool:
    It just pisses me off that GM screws people to replace a part that wasn't thought out very well in the design phase! :mad:
  11. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    How bad to change the actuator?
    I've been thinking about doing this same switch on my '95 Yukon to get better engagement. (I hate the suspense of sitting in a snowstorm and waiting for *blink* *blink* *blink* *blink*................engaged)
    It doesn't look like the actuator would be that hard to change on the truck when I look in the manual.
    Any guess as to how long of a job it really is? Anything tricky we should know about before-hand?......
    THANKS!!
    -Ben
  12. divorced
    Jul 20, 2004
    5,115
    It's not a difficult job at all. You just unscrew the old actuator from the differential and screw the new one in and unhook the old wiring harness and hook up the new one.
    Has anyone ever tried the cable type manual actuators?
  13. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Ok,
    I'll give it a shot once things thaw out here in Michigan.
    Thanks,
    -Ben
  14. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Took me all of 5 minutes when I did it on my '91. No harder than pullin spark plugs.
  15. andrew.wilson
    andrew.wilson Registered Member
    Jan 19, 2005
    35
    Wyoming
    That can be very difficult for some people :D ( the pulling spark plug thing) i.e. my neighbor
  16. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    If the actuator does not fix it I have come across a lot of the early half tons that broke the passenger side axle shaft inside the front diff.
    bigred81
  17. andrew.wilson
    Jan 19, 2005
    35
    Wyoming
    That happend to me on my 93 Z71 but it was due to abuse (and about 6 feet of air) I broke alot of other things along with it though.
