4x2 manual into 4x4 auto
Discussion in 'The Garage' started by trailblazr81, Nov 9, 2006.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    My neighbor is parting out his 86 1 ton short bed 2wd Chevy. All he's keeping is the 454 and the bed. I have a 73 longbed with 383 and TH350. I want a manual and his is. The knob shows L-1-2-3-R. Will this work with my NP205 T-case? What all would I have to do to make this work in my truck? I can cut a hole in my floor and swap out a flexplate for a flywheel, but If the manual tranny is like the TH350 where the 2wd is different than the 4wd I'll keep looking. Thanks guys.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes the 2wd is different from the 4x4 version in regards to the output shaft, you could run a divorced case, but otherwise i would keep looking
  3. dyeager535
    26,979
    How much does he want for the trans, complete, including pedals, bellhousing, etc?
    That hydraulic clutch setup alone is probably worth at least $50-100, if you can get the complete trans for that price, go for it.
  4. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Dammit!! :mad: Thats not what I want to hear!!!
  5. goldwing2000
    goldwing2000 Guest
    I thought all SM465 trannys were the same. I though the only difference was whether it had a tail housing or a t-case adapter on the back. :thinking:
    Either way, a TH350 NP205 won't work with an SM465 tranny. Different spline counts on the tranny output/t-case input. You could make it work by changing the t-case input, getting the right sleeve and the right adapter but then you'd just be further ahead getting the right t-case. SM465 t-cases are the cheapest of the NP205s.
