4x2 to 4x4 conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79burb, May 21, 2003.
  1. 79burb
    79burb Newbie
    May 21, 2003
    Missouri
    newbie here I tried the search funtion with no luck so here we go.. I have a 79 burb wanting to put it on a 4x4 frame I have a 75 3/4 truck frame with the snowplow hubs I have measured it they are close on the wheel base so is their any hidden thing I need to be aware of??? <font color="blue"> </font> /forums/images/graemlins/burb.gif
  2. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    really don't know,,, but I'm gonna say yes! theres always something thats gonna pop up unexpected. I think it's a proven fact or something /forums/images/graemlins/grin.gif
  3. bad andy
    bad andy 1/2 ton status
    Mar 5, 2003
    151
    Charlotte, N.C.
    i believe suburban frames use the same frame as one of the pickups, probably the regular cab long bed so if thats what u have i think it should work.
  4. 79burb
    79burb Newbie
    May 21, 2003
    Missouri
    Yeah they measured the same but I didn't know if they had all the right bends and body mounts
  5. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    NOOOOOOO..
    The 'burban has a 3" shorter wb than a LWB puck-up
    The frame, from the firewall back is different...mounting points etc...
    The rear of the frame, behind the rear axle, comes out at a different angle..
    ALL the running gear will interchange, EXCEPT the drive shaft...
    It would be fairly easy to convert the 2wd frame to 4wd... It only involves grinding off some rivits, drilling holes and using bolts instead...
    I have done it both ways, 2wd to 4wd, and 4wd to 2wd...
    Your entire 2wd front end comes out with a bunch of bolts, only 2 rivits on the sway bar mount need to be ground..
    The 4wd motor mounts need to be installed first, then the front spring purches, the rear shackle hangers and the sway bar mount..very easy...
    The transfer case x-member just requires 4 holes drilled in the frame...
    If you cannot find a 4x4 burban for a drive shaft,you will have to have it shortened...
    The Transmission tunnel, on a 2wheel drive automatic, is lower than a 2wheel drive stick shift, or 4x4, so you may have to cut the floor..some... depending on you trans transfer combo...
    The rear axle mounts are the same...
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
