4x4 12 bolt vs 4x2 12 bolt
Discussion in 'The Garage' started by kgblazerfive, Mar 21, 2005.
  1. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,607
    601
    Hooper, Utah 84315
    Does anybody know if the axels are interchanable, five lug verses six.
  2. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    I've swapped them...
    I put 6 lug axles in a 5 lug 2wd rear axle before--I'm not sure if all of them are interchangable though,so it would be wise to measure the bearing sizes,spline counts,overall length,etc, to make sure--someone else might know more specs than I do,but I wouldnt doubt if they are all the same--chevy didnt change too many things like that....:crazy:
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes they interchange, the only difference on the housings is the shock tabs are lower on the 2wd vs the 4wd.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Another difference is the backing plates and brakes . The older trucks had skinny brake shoes and a shallower backing plate . Later trucks have wider shoes and deeper backing plates . I reused my 83's 10 bolt brakes on my 12 bolt :k5: :k5:
    And one of my truck(s) 12 bolts IS from a 2wd with 6 lug shafts :D
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its not the years that differed in brake widths.....
    its the heavy duty springs/chassis package or lack of such that made the difference in what brakes size was installed....
    any year, 73-up years or 80-up years
    didint matter
    was all same deal, both sizes existed alot of years 70s and 80s
    2.75" and 2" wide, both
    and it doesnt matter anyways cuz all the 70 up shafts are same length regrdless of brake size
    just the backing plates and shoes differed, easy swap form any housing to any other housing
    little known secret that i found out from trial and error, you can widen a 69 older axle by using the 70s 80s 2.75" wide backing plates, drums and shoes and 70-up shafts
    regardless of 5 or 6 lug,
    lug count doesnt matter at all either
    this swap will make a 69 older axle same width as a 70-up axle
  6. kgblazerfive
    Dec 2, 2004
    10,607
    601
    Hooper, Utah 84315
    So if I have a 6 lug rear axel that was trused and beefed up with lots of exterior modifications and my front is five, cause its two wheel drive, I want to put five lug axels in the back, so I only need one type of spare, it would fit. The rears are from a 78 and 77. Brakes are going to be disc swap which for the five lug is going to have to be aftermarket racing stuff.
