4x4 camshafts, ever try?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Flipper, Nov 1, 2000.
  1. Flipper
    Flipper Registered Member
    Oct 19, 2000
    38
    West of Mpls. MN
    Got camshafts in my trucks are mosty hot rod type high lift types, now realize low end is where it's at.
    I've seen summit and jegs catalogs with 4x4 cams. Anybody use em? Happy? I think one brand was Comp. Cams.
    Thanks-Flip
    (p.s.- small block 400)
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    When I did my cam 2 years ago I called comp cams up and gave them all the spec on my truck and what I mainly use it for. They recommended a 260HE cam. I've got a 4 speed so low end grunt is what I really need or it just bogs, and this cam seems to work really well for my truck and what I do with it. I'm sure not every "phone tech" they have is competent but I had a good experience with them.[​IMG]
    Now they have the 'Extreme energy' cams, and they are supposed to be even better.
    Rene
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    I'm running the Comp Cams Extreme Energy cam and love the throttle response and low end power. (Comp Cams # 12-235-2). Has a good idle and all the components the rely on vacuum (power brakes, tranny modulator, etc) still work fine. I built the engine for the off idle to 5000 rpm range. I'm running 3.08 gears in the axles for now but will change later. Running on the highway, hills dont phase it at 65 mph indicated and turning 2750 rpm. With the exception of the Manley SS valves, Comp Cams runs the valve train. Also, using the 1.52 ratio roller rockers. You can cheat the duration factor a little more by changing to 1.60 ratio rockers but then you'll have to check valve to piston clearance just to be safe. This is not considered a radical lift cam. Running KB flat top pistons with closed chambered heads. Even at moderate speeds, no hesitation what so ever, throttle response is excellent (Q-Jet carb).
