4x4 hub swamp posssible or not ?
Discussion in 'The Garage' started by just-got-1, Oct 23, 2006.
  1. just-got-1
    just-got-1 Newbie
    Oct 23, 2006
    chicago
    i want to take off those ugly manual locking hubs off so i can put some regular rims but i still want 4 wheel drive is that possible and what parts would i need?:confused:
  2. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    uhhh, care to elaborate? "regular rims"?
    I have auto hubs but will have manuals once I put my 14/44 in. You should just stick w/ them, sure you have to actually get your butt out of the truck but reliable.
    So what rims are you wanting to run?
    -Avery
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I don't know what rims he referring too.
    You have 2 options.
    The early-mid 70's "full time" option, which would require the hub, and a 203 transfer case.
    But, according to your profile, your truck is an 89, so you can just put back the 'auto' hubs that came on these trucks. Check a junkyard, dealers still cary these things too I think.
    The auto hubs are not as reliable as the manual ones.Sometimes they don't engage if it's too cold, they rely on the spinning the axle shaft to heat an little ring in there that engages the hub. I actually pulled a lady out of the ditch once, she was running in 2wd in her little S10 blazer of the same era (same hub design) on a snowy day, lost it, in the ditch she tried to engage the 4wd, the hubs were buried in ice water/wet snow in the ditch, and they wound't engage.
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if your looking for the earlier full time style i have some i could trade you send me a email about it
  5. matneyr
    matneyr Registered Member
    Jun 25, 2005
    20
    Blacksburg, Virginia
    I don't know exactly what he means by "regular rims" but I would never, ever recommend swapping down from manual to auto wheel hubs. I've broken three auto locking hubs now in bound up situations, and bought a set of Warn conversion hubs this past Sunday.
  6. dyeager535
    26,979
    I think what he's trying to say is that he'd like to run wheels with actual centercaps. You know, like a 2wd vehicle has.
    I guess if you went IFS you could do this, but I suspect it would be pretty prohibitive to do (if possible) on a solid axle front truck.
    This is one of the reasons I *like* the stock rims. With the stock "center caps" the front hubs don't look quite so ridiculous as they do when there is nothing around the hub.
  7. just-got-1
    just-got-1 Newbie
    Oct 23, 2006
    chicago
    wanted to put some 24's or 26's on it with center caps . would the 4x4 auto hubs work of a 90's tahoe or burban
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    they didnt have hubs, so no.
    if you're wanting to put 24s or 26s on it, then you're not worried about anything but pavement pounding, so put a set of auto hubs on it and call it a day.
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Nope, 90's trucks have a completly different hub design.
  10. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    x2
    -Harrison
  11. matneyr
    Jun 25, 2005
    20
    This is just my opinion, but: Don't ruin your truck with 24 or 26 inch rims!!! Just say no! Save your money, buy a set of simple 15 or 16x8 or 10 inch black steel or Mickey Thompsons, slap on some Radial Claws or Irocs, and go four wheeling! Get some mud on it! You'll look for real, and not like a poser.
