4x4 indacator?
Discussion in 'The Garage' started by 99firehawk, Nov 4, 2003.
  1. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    1983 k5, is there a 4x4 indiactor on the dash board?
    Is the range selector on the t case shifter supposed to light up?
    tia
  2. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I'd think so, my '87 does.
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It should, check the senser and/or plug that is directly on top of the t-case. Mine quit working, got under there, sprayed electrical cleaner in the plug and it started working again. /forums/images/graemlins/thumb.gif
  4. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    but the light doesnt have anything to do with 4wd being agaged, right. if this were the case i would just leave it, unless it is as simple as rjfguitar says his was.
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Correct - The light has nothing to do with 4X4 except a visual indicator to tell you it is in 4 wheel drive.
  6. 99firehawk
    Dec 15, 2002
    491
    Ok ill check the plug in the morning? Is there supposed to be a light in the range selector ?
    thanks
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yes there is a light on the range selecter...atleast on my 90 with a NP241.
