4x4 Iron rear bumper , NWP 43 gallon bas tank, who's bought one?
Discussion in 'The Garage' started by Desert Rat, Feb 27, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    4x4 Iron rear bumper , NWP 43 gallon bas tank, who\'s bought one?
    I am getting ready to order a 4x4 Iron rear bumper with swing away tire carrier and maybe side armor. Questions for those of you who have one. I am also planning on installing a NWP 43 gallon steel gas tank. Can I keep my Class 3 hitch with the new gas tank? If I can't then I should get the receiver built into the bumper. Also, I am thinking of having 4x4 Iron make mine with a double swing away. One side would be the tire, the other I would mount a double gas can tray and fasten my Hi-Lift on as well. Anybody do anything like this? Back when I had my Bronco, I saw several similar designs on other rigs. Too much weight on the bumper? Suggestions? Comments? Pictures?
  2. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Re: 4x4 Iron rear bumper , NWP 43 gallon bas tank, who\'s bought one?
    54 views and nobody has either on their truck? /forums/images/graemlins/dunno.gif
  3. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    nope......well at least not me.....
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Great question...now we only need an answer....
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I have the 4x4 Iron rear bumper with side armor, but no tire carrier. I had a Class 3 hitch but opted to have the reciver built into to bumper, the only problem that created was positioning of the license plate. After it was all said and done, I belive the hitch would have fit, but would have hung down below the bumper, which kinda defeats the purpose. This is one hell of a bumper and well worth price, and the side armor is a very good addition, but you will have to cut your quarter panels if you brace it properly. I did cut 3" off the rear frame so the bumper tucks neatly under the tailgate. As you can see I haven't used the hitch, but wanted it if necessary, and since it is a daily drive, the license plate is lighted, the bolts that hold the plate on have lts in them.
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I have looked for the pic and can not find it. I made one bumper that had double tire carriers on it for a guy in Petaluma, Cali. He was carring 2 33" spares for extended camping trips way out. I am sure I have a pic of the bumper somewhere. I will keep looking.
    As for weight on the bumper it is not an issue, as for making your rear springs sag maybe. Bumper with 2 swings would be in the 150lb range plus a tire and 80lbs of gas.
    I know the class III will clear if you have a 1" body lift with no mods to anything on the 8" bumper. Without a body lift you would most likely have to trim the down brackets on the receiver slightly if you cut the frame to bring the bumper forward. If you dont cut the frame, or cut it less than 3.5" I expect it would clear. As for the tank clearing I have no experience with that.
    Hope that helps
  7. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I like it. I was debating on the side armor. I don't want to cut my sheetmetal at this point because body is pretty clean.
  8. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'm guessing though that if I put the two gas cans and the Hi-Lift inside, I still end up with the combined weight over the back springs anyway. With double swing aways, I get more room inside for other stuff (which would be more weight I suppose). I'd love to see those double swing away pics. I don't necessarily need a Class 3 receiver. I don't plan on towing any boats. But, I thought about having the option of popping on one of those receiver shackle goodies. With the double shackles on the bumper, I guess I really don't need to. It looks like they are way substantial.
  9. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Get the side armor, you won't miss the body pieces and unless you know what you are looking for you won't miss it and it also leaves options for larger tires, relocating the axle, and best of all it helps keep the body clean.
  10. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Derf, have you got any closeups of the rear bumper, especially where the side armor mounts? I looked at your pics in the Members Gallery and it is tough to tell.
  11. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i just installed this a few days ago. i also cut a few inches off the frame to get it up nice and snug. i am able to get my drop hitch into the receiver without hitting the gas tank. very solid bumper... can not wait to get a fat 37 hanging off the back...
  12. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    The only other thing that I can think of that hasn't been mentioned is that when you tuck the bumper under the tailgate is that you loose the tailgate springs which assist in opening and closing the tailgate, it is very surprising how heavy the taigate is. I am fixing to remedy that situation by replacing it with a P/U tailgate and a soft top, which should loose at least 300+ lbs.
  13. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    My Bronco didn't have helper springs and after Herculining the inside of it, I got a good workout bench pressing it closed every time. I can live without the springs. Looks like you simply sliced off about 3-4 inches of the lower back sides to facilitate the support struts. I suppose I could manage to do that.
