4x4 louckout hubs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pregate, Aug 30, 2000.
  1. pregate
    pregate Registered Member
    Aug 13, 2000
    83
    Fort Worth, Texas
    a mechanic is recommending i do it cuz itll ease up on my transfer case problem..
    what do you guys do?
    use hubs when youre not offroad? or not
    1979 K5 Blazer
    4x4, 350 V8
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Ummm what T-case are you using? And what are the symptoms of your problem? Also what year is your rig?
  3. pregate
    Aug 13, 2000
    83
    Fort Worth, Texas
    its all stock 79
    the chain in the case is loose, making a big "thunk" when changing gears..
    i decided to go ahead and get them.. since its also my daily driver itll save on gas alot ..
    1979 K5 Blazer
    4x4, 350 V8
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Ok, so basically you had a full time 4wd t-case. Sounds like you did the right thing. Or you could have just switched out the T-case. For for a NP205 or NP208. Would basically cost as much as the hubs and t-case fix in a shop.
  5. pregate
    Aug 13, 2000
    83
    Fort Worth, Texas
    whats the advantage of the 208?
    im a total blazer newbie :P
    1979 K5 Blazer
    4x4, 350 V8
  6. fr8train
    Aug 2, 2000
    1,712
    Maryland
    He said it was a daily driver. I use mine as a daily driver too. Then I do some weekend warrior suff too. I have never had a problem with it on or off-road. My Jimmy has a built motor and the trans. has been redone to handle the added stress. I havent broken t-case yet, so I am not about to muck with it. Besides, the NP208 has a really good low range, though it is a weak case. My Big Jimmy has a NP205 + 410hp running it, she is a different animal all together.
  7. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Oh, the NP208 will be easier to find in a yard that can be bolted up to a 305 or 350. Thats less money out of pocket and into other stuff.
