4x4 messed up
Discussion in '1992-Present Chevy & GMC models' started by eightyone, Feb 8, 2006.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    i got the 94 diesel 2500...and the 4 wheel drive takes forever to engage, i pull the lever on the floor and the transfer case goes into 4 by 4, and the driveshaft turns, but i guess the hubs dont lock or sumthin...i dont know how the ifs works hubs work. but it always goes in, just take a very long time, liek 3-10 minutes.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Most likely you have a bad actuator in the front differential. It screws into the side of the diff and has some wires going to it. It's very easy to replace.
  3. eightyone
    Apr 25, 2004
    292
    long island
    ill check it out when my fingers thaw. anyway to check if its bad, or is it cheap enough to just replace?
  4. divorced
    Jul 20, 2004
    5,115
    There may be a way to test it, but I wouldn't know how. The replacement cost will be over $100. My friend replaced one on his Z71 and also needed a different wiring harness, which was also easy to replace, and the total for all the parts was around $140 or $160 from GM..
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    ditch the stock actuator (actual name is Thermal Linear Actuator) and get a cable system for $110.00 gauranteed to work everytime. in these trucks the front axles are always engaged, they just arent engaged to the carrier. there are shift forks in the front diff that lock the assembly together. because of this if you get the cable system you can not engage the front axle, and put it in 4 low and then you have 2wd low if you ever need it. Best thing about the cable system is not having to wait for the linear motor to engage
  6. eightyone
    Apr 25, 2004
    292
    long island
    where do i pick up a cable system? and how does it hook up? sounds like a solid replacement, im not a fan of computer controlled crap. i wish i was out unlockin hubs, and not worrying ablut this.
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    summit racing has em' lock up Posi-loc . i was a little off on the pricing there 170 now, but well worth it.
