4x4 pops out
Discussion in 'Rocky Mountain Region' started by skrillla, Apr 25, 2007.
  1. skrillla
    skrillla Registered Member
    Jun 30, 2006
    38
    arizona
    i have locking hubs and somtimes the 4x4 will pop out then i just put it in nutrual and pop it back in, what could be the cause of this?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your shift forks may be worn in your tcase or they may need to little teflon pads on them replaced. It isn't a terribly hard job to do but does require that you pull the tcase and break it down part of the way. If it is bad you can usually find those cases for a couple hundred bucks or less and swap a case in better shape in. You should either have a 208 or 241 depending on what year you truck is.
    I have rebuilt my 208 a couple times and replaced parts that went bad in them. They are pretty simple and easy.
    Harley
  3. skrillla
    Jun 30, 2006
    38
    arizona
    Thanks for the info Harley, ill probaly try and rebuild it, break it and buy one to replace lol.
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    It's so easy even I did it!
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    it must bea easy:p:
  6. justhorsinaround
    Sep 16, 2003
    6,798
    Just exactly what I said.
