4x4 stuff...may be what you're looking for
Discussion in 'General Parts for Sale' started by RGV72BLAZER, Mar 2, 2007.
  1. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    ramcharger reclinable seats: 70
    sbc 350 needs a rebuild: 300
    th350 needs a rebuild: 200
    203 range box for a doubler: 100
    32 spline front output shaft for 205: 120
    steering column: 20
    toy 8" axles: 300
    gm 12 bolt: 100
    ford 60 rear no axle shafts: 100
    12" front & 8" rear GM springs: 600
    7" shackles: 40
    ORD zero rates no hardware: 35
    4wd GM steering box: 50
    D70 ubolts, brand new, just used to bolt the rear into place: 50
    d60 spring plates: 50
    spare 33s for 15" rim: 25
    15" wheels 6 lug: 20
    stock 60 cover and 70 cover: 95
    64" overloads: 20
    14 bolt spring plates: 30
    some of this is OBO. i'll get pics of all this stuff this weekend. need this gone, need to make more room in the garage. David all located in San Benito TX but will be making trips to houston and san antone this month.
  2. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    How hard would it be to mount the seats in a K5? Any pics?
  3. fendereff
    fendereff 1/2 ton status
    Jun 24, 2005
    207
    Aggieland, Texas
    you say the 350 needs a rebuild. what all does it need exactly? what does it come with? im looking for something to drop into my K20 instead of the 6.2L that is in there.
  4. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    Does it have a 32 spline input?
  5. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    interested in the steering box..any leaks...how tight...what year did it come off i need one with a small shaft for an xj shaft...
  6. blasphemous
    blasphemous 1/2 ton status
    Jan 11, 2007
    457
    Louisville, KY
    Put me in line on the 203 doubler...
  7. RGV72BLAZER
    Jan 23, 2006
    2,425
    sorry guys for the late response. was out of town....
    they mounted pretty easy in mine. not a big deal. bolted into the stock holes, but i think we used the stock brackets. shouldn't be a big hassle and they recline :D i had planned on getting pics of everything this past weekend but battery died on me. will do that this weekend tho.
    i don't think this motor is for you then. with 3.08s and 35s, i could still the make the Blazer move, but it's been sitting for about 2 years and I would rather go through it all before installing it.
    27 spline input but just found one of the teeth chipped on the intermediate shaft, but i think when you run a doubler, they include this as a new piece to attach the doubler, well that's the case with my NWF doubler anyway.....
    came off a '72 K5. really great condition, no leaks, bought it from Oreilly's about a year or less before taking my Blazer apart.
  8. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    The D70 U bolts, what grade, what diameter, are they the type where the bolts point down and do they come with washer and nuts?
    Also, can they accomodate a perch that is +1" in height?
    thx
  9. RGV72BLAZER
    Jan 23, 2006
    2,425
    i think they're grade 8, not sure, i ordered them from ORD, they're made for a D70 diameter, the u bolts point up, and they do come with washer and nuts. i think they should accomodate a spring perch that is !+". how thick is your leaf pack? i can't use them with a spring perch that is about 1/2" taller than stock & TCI 3" 64s. these thing are brand new with some surfrace rust since they've been bolted on for about 2/3 weeks. other than that they haven't seen any use, just some poser flex pics. lol. let me know.
  10. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Thanks for the info. I need the down pointing ones to match my spring plates. I dont play on the rocks so I don't see it being an issue.
  11. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    I'll take the zero-rates. You take paypal?
  12. RGV72BLAZER
    Jan 23, 2006
    2,425
    no paypal right now. money order? send me a PM and we can work something out.
