4x4 vs. 2x Cabs
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by longbedder, Mar 17, 2006.
  1. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,193
    357
    Ridgecrest, CA
    Is there any difference between a 2WD and a 4WD pickup cab in a '71 (both auto trannies)? Seems like the hump may be a little different, but I'm not sure...
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    IIRC
    All 2wds have low humps, expect big block truck and or ones with the th400.
    All 4wds have high removable humps.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  4. 72chevydsl
    72chevydsl Registered Member
    Jan 22, 2006
    12
    modesto CA
    my 70 c10 with 307 & sm465 had the large removable hump.
  5. longbedder
    Oct 26, 2005
    4,193
    357
    Ridgecrest, CA
    Hmmm...I'm trying to fit a 454 with a TH400 and NP205...guess I'll have to see.
  6. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    Only the vehicles with the four speed transmissions had the high hump from what I've observed.
  7. 72chevydsl
    Jan 22, 2006
    12
    modesto CA
    You should be able to find a large hump to bolt in place of a small hump. From what I have seen the large hump came on 4WD trucks and 2WD trucks with a 4spd.
  8. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    And big block 2wd's.
    Look at it this way...everything had a high hump 'except' 2wd th-350 auto's.
    If you don't want to cut your floor to add a high hump cover, install a body lift.
