4x4 without 4wd
Discussion in 'The Garage' started by bobalob, Oct 16, 2005.
  1. bobalob
    bobalob 1/2 ton status
    Jul 20, 2005
    157
    Everson, Washington
    Dad went to put his, new to him, 95 1/2 ton Chevy Silverado into 4wheel and got no front wheel action in low or hi. Apparently he didn't try the 4wd when he bought it a few months ago and this was the first time he needed it. He has no manual or knowledge (either do I ) about the truck so if you could clue me in on what the drive train components are and some trouble shooting or common causes that would be a big help.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    check to see if the front axle acuator is working this is a commen part to fail. You will see the actuator when you look at the front diff it is sticking out of the center section
  3. bobalob
    Jul 20, 2005
    157
    Everson, Washington
    alright thanks but as usual in Washington it is raining :( so I'll go look after I find tarp to put down over mud. How will I know if acuator has failed?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you should be able to here the actuator engage if you are near it when the truck is shifted into 4x4
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    biggest problem with these is the solinoid goes out, POS in my opinion :D
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    More than likely the thermal actuator has failed. It's pretty common on the olde thermal style. If/when you replace it, make sure you get a new electronic version.
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    or if you want for sure option 4x4 posi lock kit. cable kit for you to pull in the cab and lock in and out. :D
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Id go with the cable kit. its cheaper than an oem actuator and its gauranteed to work everytime right away. and with the posi lock you have the option of 2wd low.
  9. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Last I checked, the elec act. from the dealer was about 69-80 bucks. They want 150 + for the posi-lock.
  10. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    Anyone have part numbers?Also is there a difference between 1/2 ton and 1-ton.
  11. bernman
    bernman Registered Member
    Oct 4, 2005
    26
    ny
    did you check the fuse? to start with
  12. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    Not trying to hi jack but I called my local dealer and they wanted more like $200,On mine the fuse is also blown because the actual wires on the diff. are melted.So anyone have part numbers?Pref.the new version(electric vs thermal?)
    Thanks everyone
  13. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    go with the posi lock. In my opinion, it is the most reliable method out there, with the least amount of malfunctions.
  14. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    I know old thread but does anyone have part numbers?After the blizzard out here there almost extinct.
  15. 1986K10
    1986K10 Registered Member
    Oct 21, 2006
    16
    Ontario, Canada
    I thought the electric and thermal were the same thing? Electric coil heats up fluid to move actuator? I dunno, pay no attention to me.
