  1. mikejax87k5
    mikejax87k5 Newbie
    Sep 10, 2000
    3
    how can i find out if i have positive traction on my 87 k5?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Do you mean posi-traction, the trademark for GM's limited slip differential?
    Jack up the rear axle and put two jackstands under it. Put the tcase in neutral and turn one of your wheels with your hand. If the wheel on the other side of the axle turns in the opposite direction, you have an open differential (no posi). If the wheel turns in the same direction, you have a limited slip differential (so, yes.)
    -- Mike
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Also sometimes if they turn opposite directions its just a worn out posi
    90K5
  4. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    There might be a tag atached to the cover if it is a posi. Its supposed to be there to let you know to put posi additive in the diff fluid.
    Mostly the tag gets left off after the first service.
    Rene
  5. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Look inside your glove compartment and see if you have a G80 with the other codes. If so, then you have a limited slip diff.
  6. Grim-Reaper
    7,385
    Atlanta
    the ones on my 79 turn oposite directions when both rear wheels are off the ground but I can assure you it locks completly when under load and leaves two beautiful black marks on the pavment as it vaporises the BFG's. It pulls like mad off road and at most only alows the wheel without traction to make 3/4 of a reveloution before it locks down and pulls.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If it is a factory locker in '87 it is a Gov-lock. This locking differential acts just like an open diff unless a wheel spins fast enough to kick in the governor, and lock the clutches. If you do the test where you jack up the back end, the other wheel will always spin opposite, just like an open diff.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  8. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    Right,while the old "jack it up and spin one wheel" works on the real Posi-traction, and all other clutch type L/S, too. It won't tell you a thing about a Gov-loc. You can check the glove box, like someone said, or just pull the cover and look inside. Now would be a great time to change your gear oil, too. If you see side and spide gears, its open. Grim or someone else who knows can tell you what the Gov-loc looks like.
    Jim '80 GMC.
    It's a Wheelbase thing, You're Jeep wouldn't understand!
    http://www.bigjbear.coloradok5.com
  9. Blazer1970
    1,600
    Old Mission, MI
    A Gov-lock does have all the normal differential gears. That's why it is so good at emulating an open diff. It just has added clutches and actuating means to lock the side gears together when a wheel spins.
    Tim
  10. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    I have a 1990 K5 and when a jack it up and spin one wheel the other one turns the opposit direction. Means this it is not a limited slip? (the rpo codes say`s G80)
    Greetings from Amsterdam,
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R
  11. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    I had the cover off of my old 10 bolt (7 5/8") in my S-10 with the gov lock. It looks like a little cuckoo clock in there (very weird) some sort of centrifugal mechanism?
    River if it says G80 on the glovebox it is most likely a Gov-Lock (unless the rear diff has been swapped, or glove box door for that matter) When you jack up the rear with a Gov-lock the tires will spin in OPPOSITE directions.
    Rene
  12. River
    May 8, 2000
    121
    I did a test, drove in the dirt till a get stuck (2WD) then checked if 2 wheels where spinning in the same direction seems the gove-lock is working.
    Is there also a gove-lock in the front ?
  13. Blazer1970
    1,600
    Old Mission, MI
    No, they don't put 'em in the front.
    Tim
  14. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Well do your what to know for sure(Fact), or just a best guess.
    If you what to know for sure, its gone cost you allot of $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ ( LOL )
    Just remove the cover, can't get any simple that that !
    Good luck
