5.13 or 5.38?
Discussion in 'The Garage' started by BIGRED74K20, Jun 19, 2006.
  1. BIGRED74K20
    BIGRED74K20 Registered Member
    May 23, 2005
    82
    23
    Northwest
    i have a 74 k20 with a 350/th350/205 and D60/Corp. 14 curently with 4.56's with 38.5 bogs. im puting in a e locker up front and puting 39.5 tsl's on. so i figured im that far might as well put some lower gears in it since its not going to be a daily driver anymore. so whats your input?
  2. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    5.13 is where i wanna be and i run 44's but with a 4 spd
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    If I were you, I count on the 5.13's. I know there's a lot of talk about 5.38's for the 14 bolt but I don't think anyone actually has any for sale nor do they have an expected release date.
    That said, if 5.38's suddenly appear I would go with them. :thumb:
  4. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    5.38s should be available by fall from the vendors I've talked to. I'll be running 5.13s till the 5.38s are out.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you can "buy" 5.38s on ebay, but they arent ready...so i duno how that works. just get the 5.13s
  6. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    yea the 5.38s available on eBay are just pre-orders for when the vendors get them.
  7. BIGRED74K20
    May 23, 2005
    82
    23
    Northwest
    sounds good, do you guys know if the 5.38's are a thick gear tho
  8. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    I'm not exactly sure but from the comparison shots I've seen the 5.13s and 5.38s are the same thickness
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    There's really not much difference in the gear ratio effect between a 5.13 and 5.38.
    If the 5.38 ratio was actually available and a comparable price to the 5.13 I would go that route, but if I already had 5.13's installed there is no way I would change to 5.38's..............I honestly doubt you would be able to tell much if any difference between the two.
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i believe they are thick gears.
    ive got 5.13s with 39.5s, its sweet!!! no need for the 5.38s that dont exist yet
