5.13's impossible to find??
Discussion in 'The Garage' started by scrappy88, Sep 25, 2003.
  1. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    5.13\'s impossible to find??
    I'm trying to find someplace that has 5.13 (thick) gears for my 14FF. I'd like to get a set by Precision Gear. So far I've tried Drivetrain Direct and they said those are backordered until at least December, Reider Racing says they are backordered until April '04 /forums/images/graemlins/eek.gif and 2 other local places I tried said they were out of them and couldn't give me a date when they might have them again. Am I screwed for now? I just tore apart my 14 bolt and would like to have it back together within a month, preferably with 5.13's and a Detroit but it looks like that's not going to happen. /forums/images/graemlins/frown.gif Randy's doesn't list Precision Gear as one of their brands, so I don't think they carry them. Anywhere else I should check? Thanks!
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 5.13\'s impossible to find??
    Any particular reason you're set on Precision? Pretty much any mainstream gear manufacturer should work fine. I got mine from Drivetrain Direct, they're Motive but they were in stock. That was earlier this year though.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    damn, i wanted some thick 5.13s as well... this sux. /forums/images/graemlins/frown.gif
    j
  4. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    It doesn't have to be Precision Gear but it would be nice. Drivetrain Direct told me that the other brands like US Gear were backordered as well. My other option is to go with 5.13 thin gears (at around $320 because it's a GM part I guess) and also swap the carrier. But I'm not that anxious to blow all my money.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    did you try randy's ring and pinion?? thats were I got mine
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep. Thats what I went through at the first of the year. Took me 4.5 months to get them...
  7. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I have yukon 5.13's from randys. They had them in stco and setting in my shop floor in 3 days
  8. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    I called up Randy's today as well as a few more local places, and nobody has the 5.13's in any brand. Randy's says they haven't had them for a long time and don't know when they will get them again. Same old story. So I'm settling for 4.88's. I just want to get this damn axle finished. /forums/images/graemlins/smile.gif
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Maybe call these guys www.drivetrainsuperstores.com
    Precision Gear - RING & PINION 5.13 RATIO - THICK GEARSET - GM CORP 10.5 inch - 5.13 $261.00
    Motive Gear - RING & PINION 5.13 RATIO - THICK GEARSET - GM CORP 10.5 inch - 5.13 $245.70
    OEM Gear - RING & PINION 5.13 RATIO - THICK GEARSET - GM CORP 10.5 inch - 5.13 $210.00
    /forums/images/graemlins/grin.gif
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    just out of curiosity, if OEM gear seats are so much less $, why does anyone buy the aftermarket ones? The ff14b is a hella beefy axle, I dont see the point in getting aftermarket gears for it... i mean, how often does the ringgear blow up on da ff14??! /forums/images/graemlins/confused.gif
    j
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They do it because they don't want to change carriers to go with gears lower than 4.10. The carrier break for a 14FF is 4.10 and down, 4.56 and up.
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Im confused... if ur axle came with 4.56s stock, why would you need a new carrier for 5.13s? and what does this have to do with using OEM-made gears? lol! Im so /forums/images/graemlins/confused.gif
    j
  13. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    Actually the OEM gear set that Frizzlefry listed isn't really an OEM GM part so it's kind of misleading. I talked to those guys and the "OEM" gear they list is basically their generic in-house brand.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Correct. You'll also find it all but impossible to get a 5.13 standard ring. Thick rings are much easier to find. Having a 4.56 carrier like mine means that I will likely need to find a 4.10 carrier if I ever change to 5.13s... /forums/images/graemlins/rolleyes.gif
  15. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    If you have a 4.10 and down carrier, you can still use 4.56 and up gears, but they have to be the "thick" gears. Thick gearsets seem to run around $240. If you already have a 4.56 and up carrier, you need to use the regular gears, which are around $310. They're probably more expensive because they are in low demand since most axles came with the 4.10 and down carrier.
    And now I'm really confused! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I knew that, but I was referring to stock type setups.
