5.13's or 4.88's in 1/2 tons
Discussion in 'The Garage' started by Hossbaby50, Feb 27, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    5.13\'s or 4.88\'s in 1/2 tons
    I am going to build myself a light rock rig. I am running 1/2 ton gear, and I want max reduction.
    Will 5.13's or 4.88's survive in 1/2 ton gear? Or is the pinion just to small?
    Here are the projected rig specs.
    250 I-6 motor
    700R4 trans
    NP241 case (possibly a Klune V 2.72 box also)
    10 bolt front
    12 bolt rear
    35-37" tires
    The rig is going to be pretty gutted. Only 2 seats, truck tool box, rollcage, and gas tank. Can the 4.88's or 5.13's survive? Anyone with experience? Thanks
    Harley
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: 5.13\'s or 4.88\'s in 1/2 tons
    I wouldn't really recommend 10 bolt for rocking. Low torque engine but still slightly larger tires, a 12 bolt would be a better choice. I don't understand the question now, what do you mean will they survive? You mean will they break cause its a week 10 bolt.
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    The 10b 4.88 pinion isnt as small as some think. I bought a set I never used and took some pics of them to sell. Maybe I can find the pics to post. In them I am holding the pinion and I have fairly large hands so its a decent idea of what they look like. Ill see if I can find it.
    Nope I deleted the album. Sorry. If you want to see them I can upload the pic again.
  4. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    I wheeled for 12 years with a 10 bolt front and rear with 36" tires.Mostly in the rocks.You just have to know your limitations and not try to power up anything.In all those years I never broke a single axle.
    Oh yeah I was locked with 4.56s
  5. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    My friend has 5.13's in a 10 Bolt front with a 396 BB, and 39.5" tires. I have seen him really beat on that axle and he has only broken one shaft, and that was towing someone out. He has had no problems. I would'nt worry about it too much. Also if you are going to run a 12 bolt rear you might want to look at Warn's Full Floater kit. It would definitly add some strength, and if you did break a shaft at least your wheel would'nt fall off. Later
    -fLeXy K20
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The 10 bolt is going to be the front. The fronts can hold up. The rear axle is going to be a 12 bolt.
    The question is about the pinion gear size. As the number increases (4.56, 4.88, 5.13) the pinion gear gets smaller. I have held a 4.56 pinion gear and I thought it was a little small, and the 4.88 or 5.13 would be worse.
    I know I will probably break some front axles, which is no big deal, but I can't afford to break pinion gears.
    Rear axle is going to be a 12 bolt with alloy axles. DesertDueler (Dan) has alloys in his 12 bolt and 38.5" Swampers and it holds in a Burb, so they should hold a lighter Blazer.
    Harley
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Not sure on how those gears will stand up in the 1/2 ton axles, BUT, if you end up with a higher set of gears, think ORD Doubler.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If it isn't a hassle I would like to see the pic. I would appreciate it.
    Flexy, I am glad to hear that 5.13's might hold on in 1/2 tons. As for the full float, I might use that if I start to break alloy shafts. All the guys in AZ seem to have problems breaking stock shafts, so I think I can survive with the alloy.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, to much $ though. If I do decide I need lower gear I will do it in another more unique fashion. Since I want to run a 241 I would use a Klune V underdrive box. They bolt right up. Plus all the guys in AZ run Doublers, and I want to be different (as if a 250 I6 isn't different enough).
    Worse comes to worse I can sell the 241 with Klune V to some Heeper and get a doubler. Plus doublers HEAVY. I am trying to stay as light as possible.
    Harley
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I actually was just on Randy's R&P and they show gears down to 5.38 for the GM 12T & GM 10 bolt axles. So include this in the is it strong enough question. Thanks
    Harley
  11. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Itll be tommorow before I can do it now. PM me to remind me, Im about to hit the sack.
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    with the 700R i would say 5.13's. I don't know enuff about the pinion strength of 1/2 ton stuff, but in a pefect world, the 5.13's would help make up for the I6.
  13. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I ran 4.56s for a while in my 10s. I would not recommend going as tall as 5.13s. I would stick with 4.88s and call it a happy medium.
  14. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    If you're gonna have the bottom end torque of an inline six combined with the gear reduction of a TH700, NP241, and a Klune-V, I'd stay with a stronger gear...like a 4.10 or 4.56. For a light vehicle with an auto tranny, you don't need but just so much gear reduction...especially with a 38" or smaller tire.
  15. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I had 4.88's in my 1/2 ton gear and they lasted about 2 wheeling trips. Not exactly a good number. I will admit, I (well, maybe it was theBigdaddyof2 driving) was ramroding it somewhat when the 12 bolt 4.88's let go. I sheared 3 teeth off the ring gear. The problem with smaller amount of teeth on the pinion isn't weaker 'cause it's smaller; it is because you only have about 2-3 teeth on the pinion contacting the ring gear. This puts tremendous stress on the ring gear and chews teeth. On the contrary, I have seen Steve Frisbie wheel the pee out of his rig with 4.88's in 1/2 ton gear. He went the same places 1 ton gear went at BB02.
    I would stick with 4.56 gears and a Doubler. You will find the limits of your 1/2 ton gear are going to be the Ring Gear and Pinion. Buy some Volvo Portals and never look back!!! /forums/images/graemlins/thumb.gif
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't think I am going to actually run the Klune V unless I decide I really need alot more gear which I don't think I will need.
    I was actually thinking about running the 5.13 or 5.38 for the fact that it would be a good highway gear for the 37's and the lack upper power in the I6. Now I will have to do some more research and digging and find out about the strength of the gearsets.
  17. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I would say stick with 4.56s or 4.88s. Anything bigger, and the pinion does get alot smaller. Just remeber that the crawl ratio is alomst the same if you run a th350/doubler/3.73 gears, as it is with a 700r4/241/4.56 gears.
    Dan /forums/images/graemlins/burb.gif
  18. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Ill get those pics up soon. I am thinking about changing from Webshots since they are restricting so much now. I dont want to add anything for fear itll throw up a flag or somethin.
  19. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK I got an new album and Ill start uploading pics tonite. Its Imagestation and hopefully I can post pic now too.
    Oh and I CANT upload anything to my Webshots now. Guess Im doing good that they havent locked out most of my albums yet like they have others here. /forums/images/graemlins/angryfire.gif
  20. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK bear w/ me this MAY not work! But here goes nuttin.... OK I cant get an image to work here for some reason. AWWW WTH! Now I cant even figure out links! AHHHHHHHHHHHHHHHH!
    I have the pic up, just give me some time to figure this out.
