5.13's question...
Discussion in 'The Garage' started by 84gmcjimmy, Jul 5, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    5.13\'s question...
    okay, say I had a 14bff with 4.10 gears, obvisly I would need thick gears. But is there any difference in strength and durability of thick gears versus normal gears? And do thick gears go up to 5.13's? Thanks /forums/images/graemlins/peace.gif
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Re: 5.13\'s question...
    No
    Yes
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So by your very long and informationable paragraph, I gathered that if I used thick gears, theres nothing different except they are thick? OH! and can they be used with a locker? (i.e. DETROIT)
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, the detroit for the 14 bolt will fit any axle with an open carrier reguardless of ratio.
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    HAHA sorry. Correct. They can be used with a locker, Because it uses your existing carrier, doesnt matter fast or slow case, fits both. If its a fast case, then you need thick 5.13s.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, and also, since I can't use thick gears in a d60, what do I use?
  7. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I'm running a 14b f/f w/ 5.13 and a detroit. If you have an open diff, a detroit for these is only around $350.
    As for the 60, if you are going w/ a locker or a posi you'll be getting a new carrier anyway. Just get the 4.56 and up carrier....
    Get on ebay for the gears. Iv'e seen 'em go for less than a $100. I got a new (installed but never run) set of richmond's for my 60 for a $125.
    Haven't seen any good deal on detroits, but have seen a couple power locs for the 60
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So for the dana 60, I should look for 4.56's and up? And for the 14bff, I can just use thick gears right?
  9. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If you dont want to run thick gears in the front you can get a slow case and thin gears since your getting it all new. and thick gears for the 14b.
  10. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Yup and yup /forums/images/graemlins/thumb.gif
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Whats a slow case?
  12. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Whats a slow case?
    A case made for lower gears... in other words, a 4.56 and up case....
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    ooh okay. Thanks for the help guys /forums/images/graemlins/bow.gif
