5:13's the lowest for a 14ff ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, Apr 22, 2002.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    5:13\'s the lowest for a 14ff ???
    this sucks, i want 5:38's anyone know for sure? thx--j.c.
  2. fender
    fender Registered Member
    Aug 18, 2001
    92
    port moody b.c.
    Re: 5:13\'s the lowest for a 14ff ???
    5:13 is the lowest fro a 14 bolt. Get a D60 or 70 if you want lower, or get a doubler
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, 5.13 is as deep as it goes.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Get a D60 rearend. Then you can go all the way into the 7.__ range if you wish. This is assuming you have a D60 frontend.
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yeppers, 5.13 is it... of course, why go lower? If you need a better crawl ratio, ya could always run some kinda doubler or other trick t-case/tranny combo....
    J
  6. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    dam, i wanted 38's-40's but i also want it geared DEEP! especially with the weight of one ton axles and big meats with steel wheels. the deeper the better.
  7. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    get some 2.5t rockwells... 6.92 gears is all you can get! /forums/images/icons/wink.gif
    in all seriousness tho, I think 5.13s would be great for the size tires you wanna run. If they won't do what you need, you prolly do need more engine, or better reduction in the tranny/tcase. Of course its your rig.... if you wanna run 7.17s, its fine with me. /forums/images/icons/tongue.gif
    J
  8. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    for all the work youd be better off with a new tranny o t-case, cause youll get better ratios anyway and itll probably cost less.
  9. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    I run 39's and 5.13s and they seem deep enough for me.
    ric
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I wouldn't wanna run lower than 5.13's anyway. When you go that low your pinion gets really tiny which makes it weaker.
  11. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Just spend the money on the doubler, then you'll have plenty of low gear. And Dana 60's may have low low gears, but like said before, pinion is much weaker.
  12. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I agree, a even a Dana 60 with gears much lower than the 5ish range the pinion gets pretty small.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    5.38s?
    isnt that just an oddball JEEP ratio not available for most axles
  14. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    There is only a 5% difference between the two ratio's. You'd be hard pressed to notice that on the trail. On the highway it would only be 130 RPM difference at 60 MPH...
    Rene
  15. Blue Meanie
    Blue Meanie Registered Member
    Apr 12, 2002
    61
    southern New Jersey
    5.13's do a great job in my truck. i have more than enough low end with 39's and a 305. i have never needed more low end than that, and would be scared if i did. granted that i don't do much rock crawiling, but it is enough for the occasional tree stump and boulder, massive sand or clay hill, or a friends 38.5. i think that you will be super happy with the crawl ratio of the 5.13's with your 39's. it seems like i am only going 5mph in 4 low with the tach at 5000rpm. LOL
  16. Blue Meanie
    Apr 12, 2002
    61
    southern New Jersey
    5.13's do a great job in my truck. i have more than enough low end with 39's and a 305. i have never needed more low end than that, and would be scared if i did. granted that i don't do much rock crawiling, but it is enough for the occasional tree stump and boulder, massive sand or clay hill, or a friends 38.5. i think that you will be super happy with the crawl ratio of the 5.13's with your 39's. it seems like i am only going 5mph in 4 low with the tach at 5000rpm. LOL the 5.13's in my truck put me at 10mph over what i am actually doing, ie, 60mph on the gauge when i am actually doing 50, plus it keeps the gas milage at aroung 6-8MPG, right where i like it!!!LOL
  17. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    ya i went from 15 mpg with 4:56's and 1/2 tons (700r4) to 10 mpg with the weight of 1 tons and only 4:10's. my k5 used to haul ass, now it LAGS!
