5.14 GEARS IN 10 BOLT?
Discussion in 'The Garage' started by BIG B., Apr 16, 2003.
  1. BIG B.
    BIG B. Registered Member
    Mar 10, 2003
    48
    SAN DIEGO
    OKAY, SO IM LOOKING ON EBAY AND I FIND WHERE I CAN GET A RACK AND PINION SET, 5.14 RATIO, FOR CHEAP. I HAVE THE 8.5" 10 BOLT WITH 3.73. THE SELLER SAYS THAT THEY WILL FIT. I THINK IT WILL WORK, BUT I WANT TO KNOW EVERYBODYS OPINIONS.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    :nuke:
    quick! everyone buy stock in pinion manufactuers!
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> First off, the all caps thing is annoying and hard to read. Here are my thoughts -
    5.13s are pretty deep, what size tire are you running on that 10 bolt?
    Pinions for 5.13 gears for 10 bolts have like 5 teeth on them, strength is not a major feature.
    You're going to have a hard time fitting a rack and pinion in an axle housing. A Ring and pinion will work better. /forums/images/graemlins/thumb.gif
    Be careful with used gears, they're harder to set up and might be trashed, get lots of good detailed pics before you buy.
    </font>
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is probably 5.13's. But yes that ratio is available for a 10 bolt. The only problems I have heard of with them is the pinion gets kinda small, and the pinion teeth on ring gear teeth gets kinda low which causes more pressure and a better possibility of breaking off teeth.
  5. BIG B.
    Mar 10, 2003
    48
    SAN DIEGO
    Sorry about the all caps. I would rather by new gears any how thanks for the info.
