5/16 plug
Discussion in 'The Garage' started by bigbadchev84, Jan 26, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i have a new engine i am getting ready to stick in the blazer and am wanting to run my stock gauges and mechanical, in the pasenger side head it has a square headed plug, it is 5/16 though, i went to the parts stores in town and they cant get one, i tried the hardware store and got some 5/16 square stock but it just twisted, the plug is in there good! anyone know how to remove it?
  2. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,268
    159
    Wisconsin
    If you have a grinder take a hardened grade 8 bolt, a short one, and grind 4 flats on it so it just fits the square, then pound that in the plug and put a socket on it. It's super cheap and it should work. Good luck.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    a 3/8" ratchet drive is supposed to fit in that
    heating up and melting candle wax into the threads usually always works
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i ran into the same problem on an 88 tbi 350. the ground down bolt did the trick for me. you need a 5/8 or 3/4" bolt to start from.
    or if you have a short extension laying around, it would be easy to make fit.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Keyway stock from your favorite hardware store or tractor store works pretty good in instances such as this.
  6. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    i'm sure you'll figure something out.. i used to use ss keyway stock all the time back in the day. but they do make proper tools for all square drives... http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=65528&group_ID=259&store=snapon-store&dir=catalog
    i own male and female squaredrive sockets. vital when you run across as many drain plugs, etc as i do.. http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=1588&group_ID=259&store=snapon-store&dir=catalog
    pretty sure Craftsmen has em too...
