5.38 - 14 bolt 10.5 gears?
Discussion in 'The Garage' started by mdstmpr, Dec 15, 2002.
  1. mdstmpr
    mdstmpr Registered Member
    Apr 21, 2002
    41
    Riverside,Ca
    I'm confused, Does anyone make a larger then 5.13 gear set for a 14 bolt? I was just in the study (restroom) reading some old magizines and a couple of the trucks,said they had 5.38 in a 14 Bolt. I'm running 42"s and looking to go 44" boggers would like to go 5.38 if someone makes them. /forums/images/graemlins/1zhelp.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've never seen anything lower than 5.13's advertised for the 14 bolt FF. /forums/images/graemlins/frown.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    That ratio is probably available for the 14 semi-floater. Not sure though.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I did some research before and the lowest available is 5.13
    Like wes said, maybe the 9.5" 14 bolt has this available.
    -- Mike
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Topic gets kicked around on Pirate4x4 quite a bit... seems max 5.13 ratio is the reason guys will run a Dana 60 or 70 instead.
    Just add another t-case! /forums/images/graemlins/grin.gif
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Why doesnt a company come out with lower gears for the 14ff? is there a reason that they cant be made?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not enough demand for them I guess. I bet if everyone were to swamp name brand ring & pinion manufacturers with requests for lower gears for the 14FF, they could make something. /forums/images/graemlins/deal.gif
