5.38 in 10b??
Discussion in 'The Garage' started by Big89Burban, Jan 26, 2006.
  1. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    I got a 10b with 3.xx gears in it. What all is needed to get 5.38's in it? Need to gear the front and get the 4wd back. :D
    Can I use a d44 gear in a 10b? Will it work?
    thanks
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Parts from the D44 and 10bolt are not interchangeable. Also I am not sure that they make a 5.13 for a 10bolt. If this is for some big tires then whatever size tire needs a 5.13 to way too big for these 1/2 ton axels and will break something the first time you hit the gas. I wouldn't go bigger than 35s on 10bolts. That is what I'm running 35s on 10bolts with a 4.10 ratio.
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i think he said something even taller than a 5.13 i think it was 5.38..... hummm i smell baaaaqd stuff in the air, is it hummmmm broken everything from yoke to shafts... dont do it unless you plan on running no more than a 35 or 36...
    LUKE
  4. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    sorry, my bad it was 5.38
  5. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    thanks for the opinion guys but I just can justify waiting months/spending 1500+ to build a d60 for my truck right now.
    They do sell 5.38's for d44/10b. I just need to know wether I will have to get a new carrier or a spacer etc.
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Search the boneyards!! Find a 14 FF for the rear and a 60 front. 5.38's in a 10 bolt?? Hope its just for mall cruising and parking lot pimpin'!! Why spend money on gears and install when the first time you try something nasty its gonna snap?
  7. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    its already got a D60 rear. Just havent upgraded the front yet and I dont want to go broke trying to build a front axle.
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i had 5.13s in a 10b, never ran it tho, found a d60 just before i installed the axle back in. as long as you have 3.08 and up it uses the same carrier. carrier break is 2.73 and down or 3.08 and up
  9. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    If it's for mall cruising and parking lot pimpin wtf do you need gears for a front 10b:haha:
  10. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    if u were to spend 5:38 on gears carrier etc that will run you 3-4, why not save up another 500 and get a dana 60, ebay has them quite cheap
    dont spend any coin on a 10 bolt, live with what ya got
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what size tires are you going to run? im hoping its 35s or 36s and u just want a killer ratio. i say wait and get a 60...i found out the hard way.
  12. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    Wow at least someone provided something useful :rolleyes:
  13. blackblazer717
    Jul 1, 2004
    470
    massachusetts
    hummm, i say they will last, 5.38's are pritty tall, just was wondering from earlier, what size tire ya going to run bud...?
    LUKE
  14. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Just call Randys ring and pinion. Get a gearset and install kit. I think you also need a special cross pin. www.randysringandpinion.com
  15. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    The carrier break is at 3.73. Ratios numerically higher starting from 3.73 use a different carrier then gearsets 3.55 and down.
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It's actually 2.73up and 2.46down. The only 4 series carrier made for a 10 bolt is aftermarket.
  17. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    hes running 44'' trxus all terrains. its mainly just a nice street truck that might see some mud.
    bigburban hows the d61 doin??:doah:
  18. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    With the 5.38's in it. I couldnt be happier with my D61/D60 hybrid :D
  19. muddyblzr
    Nov 2, 2004
    623
    haha good to hear u got that straightened out
  20. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks for fixing that, i knew it had to do with 2.73 but i wasnt 100% sure which break it was
