5.9 cummins question
Discussion in '1982-Present GM Diesel' started by colbystephens, May 4, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok so i'm helping these people out with their old school bus and here's their problem - i don't know the answer. anyone got any ideas?
    everything i ever hear about diesels makes me think this should be the other way around.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Solenoid heats up and then stops working...happens to 6.2's as well.
    Rene
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    hmmm. sounds like i need a shop manual and a new solenoid.
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so is that a solenoid problem or does the heat need redirection?
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    all i know about that quote is what was emailed to me. hmmm. can you elaborate a bit more? i don't really understand your post.
  6. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    Not knowing what engine he has ,if it's a 5.9 B" I would check that fuel shutoff,just pull up the plunger ,wire up and test .Those go bad from time to time.
    CrewCab59
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, so as it turns out i have new info about their engine, which is not a 5.9 as they had originally told me. :) it's a 6 cylinder 8.3.
    anyone have anythoughts about how to fix this?
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i just reread what they wrote to me, and i think i might need more info from them - i don't think a starter would have a piston in it which allowed fuel to flow. he must be referring to the fuel solenoid, not the starter.
  9. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    Not the starter!
    Try the fuel solenoid .You can just pull up the plunger and try to start it ,if it starts then its a fuel solenoid. (check for power and grounds)
    CrewCab59
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah, that's what cummins told them. it works to pull the plunger up and start it, but he wants the problem fixed. does this mean replacing the solenoid?
  11. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    As long as you have your power and grounds, Yes replace the solenoid!
    CrewCab59
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i wish i didn't suck w/ electrical stuff. can someone walk me thru checking the ground? i think it has power since it works when the engine is cold.
  13. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    clean up the ground, to make sure its a good connection. OR if you have a tester you can do a continuity test.
