5 Gallon Sand Blaster problems
Discussion in 'The Tool Shed' started by BKinzey, May 5, 2007.
  1. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Heard they were decent so I bought one. Bought dried sand, medium grit, and a particulate mask to use for this & painting later.
    So here's the problem. Hooked everything up and the sand doesn't come out the nozzle. Air comes out great!:rolleyes: Had the pressure set to 80lbs so I upped it to 100 (max is 125). Still no sand:( I put the sand in several weeks ago so I thought maybe that was it. stuck a piece of flat stock in there twisted and stirred best I could. Fairly sure I got the center stirred all the way to the bottom at least. Still no sand:mad:
    Suggestions?:bow:
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    forget to install the sand pick up tube?
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I think you have a cheapo blaster like mine. Take apart where the hose and valve attach to the bottom of the tank. You either have some hardened sand stuck in there or you have a small rock that is blocking the flow.
    Also, you will be suprised at how much air you are going to need. When I blast, I use two medium sized air compressors (one is about 11cfm and the 2nd is about 16.5cfm) and about 150gallons of air space.
  4. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    It's a gravity fed not the siphon type. I'll check the bottom valve.
  5. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Hey! Ya open the valve on the bottom and the sand flows right through!:haha::haha::o
    http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_583_583
    So now I have a couple more questions. The "Patented Deadman Nozzle" didn't work too well. The ceramic nozzle lasted less than 2 minutes:doah:It still worked with out it but what's that all about? After some use the deadman valve got a little gritty and wouldn't close all the way and allowed air and a little sand to escape. Worse, this allowed the sand to continue into the hose and the next time I grasp the lever a fountain of sand, that is the escaping air had enough force to draw sand into and fill up the hose, once that cleared it worked again.
    Anyway to make sand work with this? With the ceramic gone I have about a 3/8" hole. The hose is about 1/2" ID. I thought I could drop to a 3/8" hose and 1/4" adaptor from the hose to the back of the deadman to get some type of regulation on the amount of "fountain" I get.
    Maybe somebody makes a better nozzle I can use? Northern Tool only has the one.
  6. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    Have you looked at TP tools, they have a large selection of blasting stuff!
  7. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    I am having all the same problems with the unit that is right above your model.
    I think these are just POS and I am lookigna t something different.
    I have a fairly large air compressor and I had it regulated fairly high.......I am going to try it again, SOON.
  8. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    ;)The gun they sent is useless. I adapted down to a 1/4" copper pipe and then got a cap. Drilled a 1/16" hole and have enlarged it twice. Plugs up so I'll have to work with it some.
    Now the problem is with no shut-off, except for the air valve on the tank, I need a larger air tank. I'm using a 20 gallon and I should have like 80
    Hopefully I'll be able to find a gun that works:mad:
    TP Tools has siphon type stuff but thanks for the suggestion;)
  9. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Harbor Freight has a different type of gun. Looks more like the type on the $$$ models. You can order the gun separate online so I did.
    I've got to say the Northern Tool one is crap for sand. Might work with a light abrasive like plastic, shells or beads.:rolleyes::rolleyes:
  10. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Got the Harbor Freight Friday:laugh: Works a lot better:D Still have a few things to work out but at least it's useable now:rolleyes:
    In the pic the Harbor Freight is in the package. Looks like both guns are made by the same overseas supplier but the Northern Tool one is crap IMHO:mad:
  11. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Still a couple of problems with clogging so the cheesy abrasive shut-off valve is the next to go.
    When it works, it works pretty well though:wink1:
  12. misterfnygy
    misterfnygy 1/2 ton status
    Jan 12, 2006
    199
    Reno
    my suggestions
    I have the same setup- with the harbor freight deadman valve. The way I get started-
    Close all the valves on the blasting unit and hook up the compressor.
    Open the inlet valve and charge the tank, I let my compressor refill
    Open the air valve to the gun
    With the trigger pressed, open the abrasive valve
    Still clogs up sometimes, just have to kick and beat on it a bit to open things up
    When I shut it down I go in the reverse order on the valves to prevent the fountain effect. Kind of a picky machine to deal with but works great once it is running....
