5 leaf 56's???????
Discussion in 'The Garage' started by rubbinz raczn, Jan 15, 2005.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    picked up a pair of stock 56" rears for my front spring swap. only they are 4-leaf plus an overload spring. all the 56's i have seen are 8 leaf ones. got them used from a local 4x4 shop. the kid didn't know much, the main guy was gone but he said they had the newer style clamps on them? the clamps have a black plastic insert in them. the springs have the wear pads also. i did some measuring and they measure 55" eye to eye, 26" on one end 30" on the other. so that is good. spring eyes are 1.5 inch have rubber bushings. the only marking i can find is on the bottom of overload where the spring touches axle pad is a 97 in yellow print? iirc chevy went to the long springs after 88 in trucks and 91 in subs. are these light 3/4 ton 56's? just wondering what i am dealing with, thanks:D
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea they made 2 packs, I had more springs which are found in most 1 tons and then the packs like you have that are found in 3/4 ton subs and some p/u, they will work just fine. :)
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    the 56's on my 90' sub has 6 leaves + overload.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Pretty certain my 89 burb is the samething. Don't feel like running across the street to see.
  5. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    yeah my 90 sub had 7 plus overload! but it had the G code on vin tag. so for the front can i leave them the way that it is or should i pull the overload?
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    um... 26+30=56 not 55 :screwy: :screwy: :screwy: :rotfl:
    ive never seen a 5 leaf 56" pack but have heard of them.
    my 3/4 ton has 5 leaf 52" pack and my half ton has 6 leaf 52" pack :screwy: :screwy:
  7. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    eye to eye 56 not total length! measure a 8" lift spring they may measure 52" or 56" but much longer cause the arch:D also a steel tape not a cloth so ballpark:yikes: for sure chevy 56's! every 56" pack i have seen is 4 inches thick in the center these look alot like the 52's just longer.
  8. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I have a set like this, came out of a 77 1/2 ton 2 wd longbox I'd junked out.
  9. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    umm ya...i have a set of 56s..from a stepside parts truck,1/2 ton 2wd..that only had 4 leaves and a overload...but the set i got from an 89 burb 1/2 ton has 5 leavs and overload....
  10. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    so leaf spring rear 1/2 tons had 56's :yikes: same as 4x4's just less leaves?
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, I have a set of 56's on my 86 1/2ton burb parts rig i just got.
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Some 1/2 ton pickups and burbs did have 56" rear springs in them. I helped Matt (az-k5) pull a set of 5 leaf + overload 56" rear springs from a 1/2 ton burb about a week ago. We installed them last week with new shackles on his custom shackle flip setup.
    We got the first test run on them today and they flex really well. The shackle angle is alot better now too and the springs are softer so his truck rides REALLY nice now.
    Harley
