5 lug 14sf from 454 SS?
Discussion in 'Parts & Trucks Wanted' started by Chris_T, Oct 14, 2003.
  1. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Long shot, but I''ll see ..
    The pinion bearing is shot on the rear axle on my daily driver. Gears are probably gone. I've been living with it, but the whine is getting annoying on my longer drive in to work. It is a 3.73 geared 10 bolt in a '94 GMC 2wd. Rather than re-do the gears in this I'd like to swap in a junkyard unit.
    I'd probably be fine with another 10 bolt, but if anyone knows where there is a wrecked 454 SS 2wd with a 5-lug 14 bolt semi-floater, that would be an ideal upgrade.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Can't you just make one with a 14 SF from the junkyard, a pair of shafts, and some brake parts?
  3. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
  4. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    Thought about that, but even assuming I could swap the 5 lug drums onto a 6 or 8 lug housing I'd probably have to buy custom shafts which would make it a little more costly and time consuming than I'm looking for for my DD. Another option would be a early 5 lug 12 bolt.
    I'll probably just go with a 10 bolt. This one lasted 270 000 km and I probably won't keep the truck long enough to really need the 14.
  5. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    Thanks .. I'll check into it
