5 lug and 6 lug 10 bolts
Discussion in 'The Garage' started by protechk5, Jan 11, 2005.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    i got a 90 k5 with a 6 lug rear 10 bolt, can i swap those shafts in to a 5 lug 10 bolt, are they the same spline count? and how hard is it to swap the shafts?
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    The rear 10 bolts had two different spline counts. I don't remember the year cut off, I think it was around 88 or so............................ :confused:
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The '90 most likely has 30-spline shafts, which were only available from about '89-'91 on Blazers. If the 5-lug 10-bolt (2wd version) is older than '88, than is most likely has 28-spline shafts and therefore will not swap.
  4. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    also the housing widths differ from 2wd to 4wd...the axles may not be the same length...
