5-lug to 8-lug?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bad Karma, Dec 15, 2001.
  1. Bad Karma
    Bad Karma Registered Member
    Oct 28, 2001
    92
    Glendale,AZ
    Got a '77 Suburban that I use to tow. Can get a great deal on a rear 14-bolt FF, so what do I need to change the front to 8-lug? Spindles-out, or would the A-arms be required, also? Will the stock master cylinder work with 3/4 ton calipers and the 14-bolt drums?
    Thanks for any help!
    Mark
    84 4Runner, beat to hell
    77 Suburban tow rig, not far behind
  2. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    the a arms are diffrent, id swap a arms out, shouldnt need a diffrent master cylinder or anything
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, dana44, 14 FF, <a target="_blank" href=http://communities.msn.com/68K10>http://communities.msn.com/68K10</a>
  3. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
    1/2 ton and 3/4 ton front control arms are the same. The differnce is the size of the balljoint. If you want 3/4 ton pieces on the front you need spindles out, and 3/4 ton ball joints.
    Chris Lucas
    <a target="_blank" href=http://www.captkaoscustoms.com>http://www.captkaoscustoms.com</a>
  4. ImpalaSS
    Feb 1, 2001
    201
    ? i thought 3/4 ball joints wouldnt slip into a 1/2 arm?
  5. Bad Karma
    Oct 28, 2001
    92
    Glendale,AZ
    OK, guys, who knows for sure??? [​IMG]
    Mark
  6. ImpalaSS
    Feb 1, 2001
    201
    to be serious id trust whatever capt has to say he knows 73-87s ALOT better than me...... im more of a 67-72 guy
  7. Captkaos
    198
    Birmingham, AL
    Only diff in the balljoint is the shaft size. A 3/4 ton should go in there. If in doubt, go to the local parts house and look at both applications.
    Chris Lucas
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well this just became interesting ! must be 73-up only thing then ? havent been able to do so on a 67-72 in the past, hmmmm
    run it til it breaks, fix it, and break it again!
