5 or 6 lug on stock 75?
Discussion in 'The Garage' started by JT Topless 75, Apr 3, 2003.
  1. JT Topless 75
    JT Topless 75 Registered Member
    Mar 3, 2003
    22
    Richmond VA
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
    I have a relatively stock 1975 Blazer that I am starting a build up on. I do not have access to this truck right now but would like to start gathering some parts for this. Can anyone tell me with confidence whether this truck with the stock 10 bolts would be 5 or 6 lug?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It would be 5-lug if it's a 2WD and 6-lug if it's a 4WD. /forums/images/graemlins/cool.gif
  3. JT Topless 75
    Mar 3, 2003
    22
    Richmond VA
    OK, thanks, yes it is full time 4WD
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    they are not 10 Bolts you have DANA 44 up front and 12 bolt out back
  5. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    affirmative, ten bolts came later... assuming a previous owner didnt do some weird swap. oughta be 6 lug.
    j
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    6 lug's. Only the two wheel drive's came with 5. /forums/images/graemlins/grin.gif
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    The old 2wd chevys are 6 lug /forums/images/graemlins/grin.gif
    Dan
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    1967-1970 2WD's were 6 lug with drum brakes all the way around, 1971-1972 2WD's were 5 lug with disc/drum combo.
  9. JT Topless 75
    Mar 3, 2003
    22
    Richmond VA
    OK, thanks for the info on the axles and lugs!!
