5 speed in my 88 K5?
Discussion in 'The Garage' started by RodsRVF, Apr 21, 2005.
  1. RodsRVF
    RodsRVF Registered Member
    Mar 16, 2005
    51
    CA
    I have a 88 K5 with the stock 3 speed with Low manual tranny. I used to have a 92 full size Blazer with the 5 speed manual in it. (I guess it was really a 4 speed with OD) Can I buy on of these and put in my 88. Is it a bolt up or ??? Also do you know what the model of that tranny would be?
    Thanks for the help,
    Rod
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    the 92 had a nv3500 i think, its an integrally cast bell housing, and fine as long as you stay half-ton, but if you want to go bigger, the sm465 (4spd) in there now is rated to 1 ton.
    i think it can be a bolt-up thing, you will have to check transmission output splines vs tcase input splines though, the current case (np208 or np241) should have a "long" 32 spline input, if im remembering correctly
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    most if not all 1/2 and light 3/4 tons were the crappy gertrag all one piece tranny and bell housing. stay a way from them. get the cast iron nv4500 from a hevy 3/4 or 1 ton truck.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ditto, getrag.
