5 Speed ina straight axle K10? WOW!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by uglytruk, Oct 26, 2006.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    I've always wondered if the non-OD SM465 could be updated to a '88up 5 speed. Well, is this it? This guy just bought it for $600. He said it started life as an auto. All I could see that was modified was slightly enlarged crossmembe bolt holes and a little trimming in the 4x4 trim.
    Whadda' ya thunk???
    OOOPS!, ignore picture # 3, it's a 6.5 diesel starter, sorry...
  2. uglytruk
    Oct 24, 2004
    1,329
    Here's 2 more pix of the 5 speed...
    Cool, huh?
    Ignore picture #3 above, it's a 6.5 diesel starter... Sorry...
  3. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    I just swapped in a 5 speed too (in place of the SM 465)
    I went with the NV4500 instead of the Getrag/NV3500 though. His swap looks clean and simple, but I'd be pretty worried about smashing the slave cylinder mount off on that one.
    Rene
  4. uglytruk
    Oct 24, 2004
    1,329
    I've never studied an '88 up, even thought the mistaken pix was from a '95 6.5 4x4 (700R4). I don't even know if the tranfer case is on the right side. I guess it is... Slave cylinder? I don't knoe if he's an off-roader...
    Tell me about the differences in NV 3500, 5500???
  5. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    The '88 up stuff is all drivers side drop, but the bolt pattern for the T-case is the same 6 hole round pattern, so a passenger side drop case can be easily bolted up.
    The Getrag/NV3500 were both light duty all aluminum 5 speeds. No granny first gear. They used an integral bellhousing so there is no option but to have the slave on that side of the tranny. IIRC OD was .70:1 just like the 700R-4 and they're a pretty smooth shifting 5 speed...a lot like a car tranny.
    The NV4500 is very similar to an SM 465 as it also has the granny low first gear. It's also a cast iron brute like the SM 465 too. Factory bell puits the slave on the wrong side, but Advance Adaptors makes a few different aftermarket bell's for the swap.
    The NV4500 has some gearing variations, early years had a 6.34:1 first gear and later years used the 5.61:1 first gear. Mine is a '95 and has the 5.61:1 first gear. OD is either .73:1 or .74:1 depending on who knows what. I really don't know if anyone would be able to notice the difference.
    The NV4500 is also supposed to be a smooth shifting tranny, although not as smooth as a car tranny. I'll let you know when I finally get to drive it (I'm not done yet)
    For a light duty DD 1/2 ton I'd seriously consider the Getrag/NV3500 though. It's bound to be a bunch cheaper than the NV4500.
    Rene
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    But will the NV3500 stand up the power from a healthy V8 with 35s and a heavy right foot?
    Also can you power shift the NV 5 speeds?
  7. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    The Getrag/NV3500 is a bit weak, although I did have one in an '88 C1500 with the 350. I can't say I was very nice to that tranny, second gear used to be good for about 20 feet of rubber, third another 5-10 feet. Power shifting it was easy. I sold the truck with 70,000 miles on it and only ever had to replace a pin in the shifter assembly.
    The NV4500 would take the punishment, but I doubt it'd be as easy to powershift. It will definitely shift smoother/faster than the SM465 though...but has the same horrible gear spacing so it's kinda pointless.
    Rene
