5-speed tranny from a C70 chevy truck
Discussion in 'The Garage' started by steelsoldiers, Sep 23, 2003.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Any ideas what tranny it may be? A guy in the local ad trader has one for sale with bell housing for $350. I'm sure it has a yoke on it for 2wd applications, but could it be made to work in a 4x4? Is it an OD 5th or a 1:1 5th? He wants $350 for it. Thanks.
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    probaly a clark or a new process some have overdrive some don't super strong but a little on the heavy side for a Blazer /forums/images/graemlins/truck.gif
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    My neighbor used a clark in his 79 K3500. He managed to stick it between a Caddy 500 and a FWD transfer case, so anything's possible. I would venture to guess the 5 gear is 1:1, but it's only a guess, and I'm not where I can ask him otherwise I would.
  4. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    The transmissions in these vehicles are generally Eaton (Fuller) units. The 5th is 1:1. They are strong, but weigh an incredible amount (trans alone is 300#). Due to the big input spline, they require a big tractor trailer type clutch (I believe mine is a 16") which only works with the flywheel, bell housing & starter designed for the C60-70 truck. This large diameter will likely make exhaust fitment a problem as well (trans mounts are usually on the bell housing). Hope this helps.
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Clark/Fuller 5th gear is 1:1 ratio. Heavy as hell. /forums/images/graemlins/grin.gif
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I drove an '86 C60 and an '82 C70 that both had a Clark 5-spd according to the RPO sheet. Not sure if it was direct or OD 5th. It looked bigger than an SM465, but still a single-countershaft transmission. Divorced t-case would be the answer... but a K5 doesn't have enough wheelbase /forums/images/graemlins/frown.gif
    Be careful about the input shaft size! If its from behind a 350, the trans will be a direct swap for an SM465. If its from a 366/427 its will be larger - these trucks have an adapter to an SAE pattern and use a 13" twin-disc clutch.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yes, very strong and more than likely an Eaton Fuller. It would probably need a 14" or 14.5" clutch. Heavy? Yes, SM465 trannies are about 140 pounds and the fullers can be over 200 easy... I guarantee it will be hard to frag, though. Also, the U-joint would be MUCH larger than you have. There are many different models. Pull the number for it off the tag. If you display it here, I could get the info for you...
  8. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    [/ QUOTE ] Some do have overdrive fifth gear also it could be a new process trans We have 2 C-60's that have new process trannys one with overdrive on without we also have a C-70 with a non-overdrive clark with a 4-speed brownie behind it . my mom and step dad have a ex-power company truck a 66 C-60 4x4 with a 409 engine and a Overdrive clark 5-speed and a 2-speed t-case and a 2-speed rearend (which sucks cuz you can't use the 2 speed rear in 4-wheel drive or ......BOOOOM) other than that it's an awesome truck
  9. steelsoldiers
    Oct 17, 2002
    365
    Wow guys, this forum never ceases to amaze me with the knowledge contained inside /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif. I'll call the guy tonight and see if he can give me the information off of the tag. He said it comes with the bell-housing and an adapter to mate it to a big-block. I don't know that I would ever need that much tranny behind my weak-ass 6.2L /forums/images/graemlins/blush.gif, but the unfraggability would be nice, especially if it's an OD. Thanks again for all the info /forums/images/graemlins/deal.gif.
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    There was a guy down TX way somewhere that was making the parts to put the Clark's in LD 4WD trucks as a less spendy option to the NV4500. Might look him up and see what he can do to marry a t/c to what ever it is you've found.
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    That will be the big shaft.... Hopefully you can stuff the 366/427 pilot busing into the 6.2L crank. Then you'll have to mess around finding an 11 or 12" clutch disc for that shaft to use the stock 6.2L flywheel and pressure plate. Alternately, you could look into having the monster 366/427 flywheel balanced for the 6.2L - then you can run the 13" twin-disc /forums/images/graemlins/thumb.gif
    I don't believe in too much tranny for an engine. More tranny just lets you move more mass with less engine strain.
    Damn! Now you've got me interested... I'll have to find my own monster tranny now /forums/images/graemlins/thumb.gif
  12. steelsoldiers
    Oct 17, 2002
    365
    oohh, ooh, oooh{tim the tool man noises}, 13" twin disc, that sounds nice. /forums/images/graemlins/thumb.gif I couldn't get a hold of the guy last night. I'll try again tonight and see if I can go look at it. Yep, he said it was behind a 366 big block in its former life. Should that mate up with the SM465 clutch linkage? That would be sweet.
