5 speed?
Discussion in 'The Garage' started by bigbadchev84, Feb 3, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    what would i need to make my truck a 5 speed? it is already a 3 speed w/ granny low and a 208 t-case what parts would i need?
  2. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    You'll need an NV3500 or NV4500 tranny with bellhousing for starters. If you go with the NV4500 you'll need a T-case with a 32 spline input shaft, not sure what the spline count is on the NV3500...I wouldn't use it anyway.
  3. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    My rig has an NV4500
  4. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    nv4500 all the way
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    Lucky guy! :thumb:
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    NV4500, give Advance Adapters a call!
  7. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    The nv4500 4x4 tranny is a direct bolt to the t-case that you have, you will need the bellhousing and salve cylinder for the nv4500 also,yours wont work.
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    3500 is junk, weak trans, seen one blown to bits behind a stock TBI 350.
  9. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    So What Truck Would I Look For With The Nv4500? What Is A Good Price For One?
  10. jwglover
    Jun 2, 2003
    88
    The one I used was out of a 97-2000 chevy trucks(mostly 3/4 ton or one tons ) they also have the newer internal slave cylinder.The slave cylinder is inside the bellhousing instead of hanging on the outside.
    I got the bell housing and transmission,the 208 tcase out of a 4spd or a 400 auto will bolt directly to the nv4500 without any adapters, and then just had my local NAPA mate the two hydraulic lines from the 87 and the 97 together.
    Works good.
    Good luck.
    If you cant find one give me a call at work, 800 627 2100 x 227.
