50 psi at idle on rebuilt 350 with high volume pump????
Discussion in 'The Garage' started by down4thakrown, Jul 26, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the psi's go up with the revs as in : 50psi at 1-2000 rpms, 75psi at 3000rpms, bout 80-85 at 4000. could there be air in the line?? or is this normal when haveing a 274 lift/duration cam??
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have heard 10 psi for every 1000 rpm is fine . 50 psi at idle sounds good to me . My engine does 50-60 at idle with 140,000 some odd miles on the bottom end . Now , later model trucks have an 80 psi gauge , got one for mine off a later second gen . I haven't changed to the 80 psi sender yet .
    With the 60 psi gauge and sender , it did peg it driving .
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Not sure what pump is in my 383. But at idle my factory 60psi gauge is pegged.
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    ive got a 1991 caprice police 350 (crappy motor) and it pegs at idle.... 60psi gauge isnt good enough :haha:
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    20-30 at idle is all you need. 35-40 at 2,000 rpm. 60-65 at 6,000rpm.
    Anything more than that and you're just increasing pump wear, distributor shaft wear, distributor gear wear, cam gear wear, and increasing parisitic losses.
    The pump should've come with a 70psi relief valve in it.
  6. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Gee..........i hope you installed a deep-sump pan with that high-volume pump that will suck a 5 qt. pan dry at high rpm's.. :crazy:
