500 caddy info post (please help out the cause and add to)
Discussion in 'The Garage' started by big_truxx, Jul 1, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    what's the bore and stroke on the 500?
    dd2000 does not have cadillac in there lol but I am assuming that using a "454" and putting in the correct bore and stroke there would be no diff anyways :D
    looking to get a general caddy 500 info post going here so it will be easier for people to locate info.
    thanks
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    500 CID
    4.300" bore
    4.304" stroke
    6.750" rods
    1.900" compression height
    10.810" deck height (measured from crank centerline)
    1.57:1 rod ratio (short rod stroker)
  3. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    what was their compression ratio from the factory?
  4. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    also some links to 500 caddy sites would be imensely cool here :D Like for parts and whatnot
  5. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
  6. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    i dunno...probably around 8.5:1
  7. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    depends on the year. You can build up to 13:1 using 472 heads as I remember. That could make a monster Propane engine.
  8. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    am thinking about a gasser for a hotrod project. and also to see what #'s a stocker would produce :D
  9. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    They say the stock 472/500 cams were very poorly designed due to the emissions requirements of the early 70's. Most important thing to do is get a modern cam like an MT3 or MT5 for much better performance.
    I got an MT10 into my 500 but haven't installed the motor yet. I'll post how I find it (compared to a stock motor, but I drove it while it was still in the car, nevertheless, it will be some comparision) when I put the motor in.
  10. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    The mt10 is a sweet cam! I really wouldnt recommend anything smaller. I built a76 500 stock short block with 120,000 miles with pocket ported 120cc heads (not best for flow) stock valves, performer intake, mt10 cam and kit and sanderson headers 750 edelbrock carb. The engine went into a 76 ford f-250 crew cab. The truck was very quick for its size and with the 700r4 got pretty good fuel economy. Anyways the mt10 was the best all around cam that I have seen, it made power all the way to my 4800rpm redline and made so much low end torque you could smoke the tires with anything over 1/4 throttle it idled with 18in/vac at around 650rpm! By the way the truck ran regularly into the low 14s!!!!
  11. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    I do not know much about the 500's (duh I started this post :D) lol so cams are one thing I will look into for sure. My philosophy is that if I am rebuilding a whole motor it is so much easier just to put all the good parts in from the start rather than wish I did later on ;)
  12. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Moturbopar,
    Thanks for the positive info on the MT10 cam. I was wondering if I should have gone with the MT5, but from what you've said I now feel the MT10 was a good choice. :D
    What kind of gears and tires did you run? Rpm's at highway speeds? How well did the 700r4 hold out with you truck?
    THanks
  13. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    http://users.elknet.net/mts/index.html
    I think 500cid.com is suppose to be a pretty good site too!
    I had a 472 in my old blazer. It had 350/205 behind it and would spin the 38.5 tsl radials (14bff 4.10's gov-lock) pretty easy.
    It was fun to drive!
  14. moturbopar
    Feb 9, 2005
    387
    mesa az
    Hi the truck ran 3.73 gears with 32"tall tires I dont remember what the rpm was at 75. The 700r4 was a well built raptor series and was way too much money for the extra 1.5 mpg
  15. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i have a 78 500 with a 400 behind it sitting in my boneyard of stuff to do something with someday . :confused:
  16. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    to sell to me :D :waytogo:
  17. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    here's a link that might help www.500cid.com, they had a crate motor that put out 450 hp and over 600 lb ft torque for around $3500
  18. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
