500 caddy swap questions
Discussion in 'The Garage' started by YELL78, Jan 8, 2007.
  1. YELL78
    YELL78 Registered Member
    Feb 27, 2005
    54
    ALBUQUERQUE
    hey guys just wanted to ask the guys that have done this swap what problems if any did you run into? i am considering doing this swap in my 78 pickup i want to keep all the ac and stuff because its still needs to be able to be driven daily. the ony stuff that i know is different and might cause me some isues is first motor mounts then the ac stuff and also i kow the bellhousings are different. Any help you all could offfer would be great and any pics of the above things would be even better. Thanks a lot.
  2. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    look up project torgue that will tell you everything you need...
  3. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    As far as swaps go, it's fairly straight forward. The caddy is a GM based engine. I wouldn't be a bit surprised if all the AC stuff had the correct fittings. I'll be finding this out soon enough. Engine mounts are probably the hardest part. The caddy stuff is approx. 5" further forward on the block. You may have to massage the firewall a little.
    Bellhousing isn't really to major, adapter plate or use the 400 that came off the caddy, switch guts with another 400 4x4 version trans and go.
    Oil filter location is less than desirable for some. Mines causing major havoc. I haven't wheeled it very hard and knocked out two of them already.
    Big block headers can be modded and new flanges added to bolt on. I believe you can use the manifolds with no issues.
    Only other thing I can think of is the linkage for the carb is wrong and will need to be modded.
    Oil pan! you need a rear sump pan off a 425 and then they aren't exactly right. Some outfits out there selling rear sump pans that will bolt right on and go in your chevy frame.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
  5. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    eldo pans are hard to find, but an easy fit.
