500 caddy
Discussion in 'The Garage' started by blazersnburban, Dec 10, 2006.
  1. blazersnburban
    blazersnburban Registered Member
    Nov 30, 2006
    80
    tunica, MS
    when you put the 500 cad in these trucks, what trans do you use? the b.o.p. trans that has a short tailshaft and converted to a 4x4 trans?:confused:
  2. mattman4x4
    mattman4x4 1/2 ton status
    Feb 16, 2005
    186
    Salisbury MD
    If I put a 500 caddy in my truck I would use a TH400, and NP203 (its what I have already)
    just my though!
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Get a BOP TH400 that came behind them from the factory. Rob the tailshaft and tailhousing from your current TH400 and swap it in. Other than the bellhousing, there is nothing about a BOP TH400 that's unique.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    They make an adaptor that will mate a Chevy bellhousing trans to a BOP engine I have one on my buick motor (came out of a chevy truck)
  5. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    yup...
    Those adapters can be had from Jegs or Summit Racing for about 70 bucks..they work OK,no need to swap a different tranny in for a 500 Caddy..I'd be easy on the accelerator if you had a TH350 or 700R4 though,the torque monster 500 could shred one if you beat on it!..
    Actually,you can use the original Caddy TH400,if you swap in a short 4x4 output shaft and tailshaft..a few guys I know are running 472's and 500's in 2wd trucks using the Caddy's original tranny,they have a super long tailshaft with a different bolt spacing on the tranny mount,different bell housing bolt pattern to match the Caddy block--but other than that are identical to a Chevy TH400 ..the OEM Caddy tranny's are pretty beefy--they used extra clutches,knowing they weighed 3 tons,and were likely to see hard use..:crazy:
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, we noticed the extra clutches when we were rebuilding mine...we thought the rebuild kit might have shorted us clutches but Terry counted 'em and sure enough, there was 1 extra clutch in each pack.
    Also, sorry, you don't need the adapter, but I got a my caddy motor and th400 for $200 so it was more feasible for me to swap parts between transmissions rather than buy an adapter plate and TRY to run a 700R4 behind that monster.
    I can't wait to fire it. :D
  7. blazersnburban
    Nov 30, 2006
    80
    tunica, MS
    thanks for the replies guys...thinking about building a 500 cad for torque and was curious what you were doing to put them in.
    i didn't think the bop trannies tailshaft bolted off like the chevy's, but if thats the case sounds pretty much straight forward!
