500 Caddy?
Discussion in 'The Garage' started by Ruthiford, Jul 15, 2002.
  1. Ruthiford
    Ruthiford Registered Member
    Jun 25, 2001
    37
    Denver Co
    What is involved in a Caddy swap into a blazer?any Tips from the guys that have done it?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i wanna know too only in my suburban. like there's any differences... /forums/images/icons/smirk.gif
  3. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Mine is a long ways from running but the hard part is done. The engine casting is completly different in many ways but the important ones are the engine mount ears (GM flat mount to block) that are about 5" forward of the GM mount position. Also the driver side cylinder sits back and the passenger side is forward which will cause a little interference at the fire wall. Also they used at least 3 different oil pans and you want the rear sump pan to clear the crossmember. I have pictures of the mounts that I made for mine posted on the new photo gallery. Look for "45acp" and you will find the pictures.
  4. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    For starters I'd try to find a running rear wheel drive 500 caddy as the donor. You'll need the engine mounts and BOP TH400 tranny. I thought the swap was pretty easy although my foundation was a tired K30 with a 454 th400 np205. It may be more difficult if you are starting from scratch with a different drivetrain.
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Sounds hard. Especially for me. /forums/images/icons/frown.gif
  6. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Look up Maximum Torque Specialties on the 'net. An excellent site for Cadillac performance and swap stuff. Even shows a Chevy 4x4 truck with a Cad motor swapped in. The site claims that the 500ci Caddy will blow away a 454ci Chevy setup...Anyway, its a good site with a lot of information.
  7. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
  8. madmike
    Jan 23, 2002
    496
    ohio
    /forums/images/icons/grin.gif YEAH! /forums/images/icons/grin.gif
  9. BigBadCad
    Dec 18, 2001
    109
    minneapolis, mn
    For less HP the 500 caddy will out muscle a 454. The only downside is the disparity in aftermarket preformance parts. If you want cheap torque, a stock 500ci is hard to beat.
  10. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    talk to bigbad75k5 he might can help
    nathan
