502 GM CRATE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ducati-cooter, Mar 27, 2002.
  1. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    HAS ANY ONE EVER PURCHASED A GM PERFORMANCE CRATE 502 FOR THEIR K5. HOW DID YOU LIKE IT, WHICH ONE DID YOU PURCHASE AND WAS IT WORTH THE PRICE.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I haven't bought one of there 502's, but my dad did buy there "targetmaster" 350. It ran well until a few rings decided that they weren't happy campers. But good thing the GM crates come with a warranty. Now I have there 300HP 350 crate, and it is totally worth it. It runs real good, and has pretty good power. I know a guy that bought the 502HP 502, and put a new set of heads on it, (est. 600HP) in his 72 longbed pickup, and broke the 12 sec quater with it. I do like the GM crate motors. They have a decent price tag, and a warranty. You can't ask for much more.
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I've sold a couple of em. One of them went into an 85 3/4 ton camper special. Stock size tire and stock dog dish hubcaps. Can you spell sleeper?
    Jim
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    We have a early-90's 1-ton crewcab 2wd truck here at work that got a crate 502 when the truck was brand new (it's used to pull a road surface testing trailer). The 502 version in the truck is what I believe they market as the towing motor and rated at around 350 hp or so?? It has an aftermarket TBI unit with specially programmed ECM and dual exhaust (no cats). The 502 will run circles around the stock 454 that was in it and with the truck empty it will lay some serious rubber down (4.10 posi). I'm not sure how many miles it has, but there are absolutely no leaks and it still runs just like when it was new.
  5. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    hey jim,
    I am in la mesa..what is your cost for a replacement unit for my 87 350 TBI. Do you have the 270 horspower option? Thanks
  6. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Big Blue
    We have the stock replacement 5.7 or we can browse the GM Performance catalog. The best thing to do is get the stock replacement 5.7 . 3 year 50,000 warranty parts & labor. Call me at work in a.m. I'll make you an offer you can't refuse...
    Jim
  7. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I have the 502 HO in my 70 Jimmy...just fired it up this weekend for the first time. It'll be a while before I could give you any info on how it drives. Where else can you get an easy 450 horses?
  8. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    so we have a gm parts guy here from san diego and nobody told me? whats the drive to bob baker like, from escondido? do you take part lookup requests? /forums/images/icons/smile.gif
    mike
  9. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I work saturdays and get mondays off. Give me a ring tuesday or post it here. One way or another I'll get back to you.The drive is worth it if you need a good deal on factory parts. 40 min drive approx.
    Jim
  10. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I bought the Ram Jet 502 and just finished wiring it a few days ago. I still have about 2 weeks till i will be ready to fire it up. Oh, its goin in a '72 Jimmy.
  11. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    "I have the 502 HO in my 70 Jimmy...just fired it up this weekend for the first time. It'll be a while before I could give you any info on how it drives. Where else can you get an easy 450 horses?"
    Thats an easy question out of any 68-76 cadlillac with the 500 c.i. engine. why spend 15K when you can get the same of better for about 3k. :P
  12. k30gambi
    k30gambi 1/2 ton status
    Dec 24, 2001
    108
    illinois
    I was looking at GM's 502 motors, I think the 450hp 502 costs around 5000 bones? Then I was looking at my summit catalog and they have their hardcore stroker setups that give you 496, 509 and 540 cubes, all coming with 4.25 stroke
    (stock 4.00) forged cranks and Manley con rods and whatever pistons you want. Anyway that bottom end costs 2000. I think if you combine that kit witha 4-bolt seasoned block bored .030 you could hang together at 5500 maybe a tad higher (yikes!). And i've got the old 049 casting heads with 2.19, 1.88 valves 400 bucks. I think this combo could make more than 450 horses for less of a price than the
    GM 502. I was thinking of doing this, you guys think it would be worth it???
  13. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    Check This !!
    1971 ELDORADO: V-8 ENGINE: Eight-cylinder, 90 degrees V-type. Gross HP 365 @ 4400 RPM. Bore 4.30, stroke 4.304, displacement 8.2 litres. Gross torque 535 ft.-lbs. @ 2800 RPM. Compression ratio 8.5 to 1. (SAE net HP 235 @ 3800 RPM. SAE net torque 410 @ 2400 RPM.)
    I think they got better too! 8.5 to 1 CR!! I was looking at this but ran accross a ZZ block that was pretty cheap and I'm just too damn lazy to do the conversion
    You can see more at :
    http://www.cad500parts.com/
