513 gears w/ 35" tires?
Discussion in 'The Garage' started by sputch, Aug 6, 2005.
  1. sputch
    sputch Registered Member
    Aug 4, 2005
    5
    Seattle, WA
    Will running 5:13 gears and 35" tires make my freeway experience a nightmare? This is a 14FF locked and Dana44 open.
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    I would think youd get a killer launching type effect out of the hole :D i was gonna run that setup at one point and time, i think it would be fine. IF you have a 700r4.
  3. sputch
    Aug 4, 2005
    5
    Seattle, WA
    Forget to mention that. Yes its a 700r4 as well.
  4. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    now i could be wrong but i had a tranny shop tell me one time, that with the 700r4, 35s and 513s..you would have a nice crawl ability, and when the over drive kicked in, it would be equal to 410s...
    don't know how true that is tho..
  5. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    actually it's way taller than 4.10 ..
    Fourth gear: 0.7 x T-case high: 1 x Differential: 5.13 = Final Drive: 3.59
    i would do it ..i'm gonna run 4.56's with 33"s
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am running 4.88's and 35's, I wish I had went with 5.13's. At 65mph I am turning about 2200 rpm and up around 75mph I am turning around 2800.
    I say if you have a 700r4 then go for it.
  7. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    why is it so dependent on a 700r4?
  8. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    ^Overdrive.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    700r4 has overdrive
  10. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i cant wait to have 5:13s driving my 36's
    the 3:42s are just killing me
  11. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    35" AND 3.08
    Yea I need to re-gear. I haven't put my truck in overdrive in the 2 weeks I've had the tires. Still waiting for that cheap D60 to swap in before I do gears
  12. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    :haha: :haha: :haha: :haha: good luck with that.
  13. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    700r ? dont forget his big brother 4l80-e:wink1:
    5.13/35 tires = lots of eating rice:D
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    if you do alot of 80+mph commuting i would go with 4.88
    otherwise 5.13 with a 700 that has a functioning lockup converter would be sweet. especially for a weezy stock engine.
  15. 85454blazer
    85454blazer Registered Member
    Apr 24, 2005
    5
    NY
    I am running 5.13s in my 60 and 14 bolt with a 454 turbo 350 208 2500 stall convertor and at 65 I am turning 2900 rpm with 39.5 boggers/swampers
  16. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yep, go 5.13 and don't ever look back. :grin: the 700 has a nice low 1st gear (for an auto) as well, so you'll have good 'launching' ability.
    j
  17. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I've got a 1954 M37 Dodge (Chev is dd and heavy wheeler, M37 project truck) with 5.83 diffs. I plan on running a 350/700r4 and Q78-16 Swampers.
  18. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    No reason not to run 5.13s, if/since you are gonna regear, on a truck with an OD trans. OD will bring the gearing down so much like others have said, bringin it to a reasonable level...plus it gives for flexibility if you ever wanna go bigger...even 44s if you wanted (not that i would ever do that). Im gonna be gettin a 14b in a few weeks, gonna gear it to 5.13s, and run my 33s for a lil while...its all i got and can't afford the whole 9 yards at once. It will be a fun lil ride to work and back and i shouldn't have to worry about freeway driving with it...I wouldn't want to run 5.13s with 35s if you do A LOT of freeway driving...but if you do a lot of wheeling and city driving, i say go for it.
  19. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    WOW.. wish I had overdrive...
    I churn 3000rpm's @ 74mph!!!!!! hmmmm nv4500 time??? :bow:
    oh yeah 4.56's and 40" hawgs (38.8 true)
  20. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Gross, I have 4.10 on 36's and that has NO balls in OD up here.
