52" front hanger move pics
Discussion in 'The Garage' started by rubbinz raczn, Jan 27, 2005.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    did the front 52 inch spring swap a couple days ago. at that time i moved the front hangers forward 4" the shackle angle was crappy, straight down.tonight i finished moving the rear mount forward a couple inches. much better :D i still plan on using 56's that i have for the front. however i wasn't happy with shackle angle with 56's even with just frame weight on springs, so i threw the 52's in! the 56's had the shackle too far back imo. i like the new shackle angle of the 52's but would like the extre flex from the 56's. my plans are to to extend the front frame 4 inches or so and move front hanger forward 2"-3" i plan on using a stout crossmember-winch mount at front of frame anyways so might as well do both. i moved the front spring rear mount forward a couple inches. used the lower front mount hole as a reference. then drilled a new 2" hole for the bushing. welded the cut out part into the old hole. i had to weld up the front hole from the old mount cause it was partially in the new mounting hole so i didn't have a too large of hole. i then drilled 3 new holes for mounting bolts. i upgraded to 1/2" grade 8 bolts throughout. by the way this swap does kind of suck but just grind-drill and it's over soon :D pics
  2. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    think i remember someone saying a lil while ago the 56s flex the same as the 52s. i dunno, but just a thought
  3. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    if that is the case that would make things a bunch easier staying with 52's!
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    much better
  5. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    why???
    you dont have to drill a new hole in the frame for the shackle mount w/ the 56s right?
  6. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    do you have any pics of the front hanger?
    mine seems to be hanging off the end of the frame
  7. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    when i had the 56's on, i felt the shackle was laid too far back! whiterhyno hasn't had any trouble with his and he didn't move the rears. i felt to make it work i would have had to move front hanger forward more. but i am already at the furthest i can without extending frame. which i may still do it just depends on how the rest of my deadlines go! :D
  8. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    i will post a couple later. i am at work now:mad:
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    52's do not flex as well as 56's do. I helped a buddy put 56's in the back of his K5 inplace of the old 52's. The 56's are WAY more flexy then 52's are.
    Harley
  10. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    there is such a thing as "too flexy", IMO. Ive seen some pretty crazy droop out of 52s with them unclamped. Looked like plenty for me, especially in the front end. My big BBCS shocks only have 15" of travel anyway. Anyway, good pics, looks like a good mod for others to copy, me included. You just use a regular metal hole saw for the bushing hole?
    anyway, whats the hole-to-hole length on your shackles again? any report on amount of lift with your current set up vs the standard spring lift? (if you had a spring lift on this rig...) I wannt get 5-6" out of my 52s... wondering what you got.
    j
  11. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    here is the pic with the front hanger.
  12. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    yeah the hole saw is just a bi-metal 2" job. used with a low speed 1/2" drill. the shackle are 7.25" hole to hole. got em from whiterhyno, thanks brad! uber stout:D the truck had a 3" tuff country lift with rear blocks. and a heavy rear flatbed. i tore the drivetrain out in one day so no basis for measuring stock vs lift sorry! by the way just so everybody notes it, the pics i have shown are just the mock up pics. just to get the springs etc. bolted up. if you see washers missing or bolts not big enough as with the shackles. once i have the final setup figured out i will use grade 8 bolts throughout, replace stock rubber bushings with poly etc. just want everyone to know pics you see are not final install.:rotfl:
