52" front spring guys
Discussion in 'The Garage' started by CyberSniper, Jul 11, 2004.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    52\" front spring guys
    What are you running for leaves? Which ones did you remove if any?
    What are your shackle lengths on center? 7"? 7.25"?
    Any tricks to flipping around the front spring hangers?
  2. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    Re: 52\" front spring guys
    I only removed the overload. No need to remove any others. My shackles are 7.25 on center. no real trick... just remove the rivets and move them to the forward holes.
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Stock 4+ overloads for me.
    7.25" Shackle
    Only trick I can think of is using the plasma butter the cut the heads off the rivets.
    Clicky
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Wow, those pictures are awesome. Thanks.
    How much lift did it net you? I'm aiming for 4-5".
    What did you use for bushings, sleeves, and bolts? The stock 7/16" front stuff looks way too girly and the stock rear stuff might be marginal too or what?
    It looks like you can take the front hangers and flip frame rails so your core support stays in the original spot. Have you noticed the same thing?
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Micah, i'm looking at the same setup for my rig, how is your pinion angle?
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    You don't move the core support. Just the little L piece behind the core support mount. Just move it in front of the core support mount, or I took a piece of angle iron and used that instead.
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Right around 5"+ of lift with the 7.25" shackles.
    It has the stock bushings, sleeves and bolts for the time being. One of these days I might put somethin bigger in there. Just gotta get motivated.
    As for the core support thing... What Poohbair said. /forums/images/graemlins/pimp1.gif
  8. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I had 56's and pulled 2 out, to leave me with 6 springs. It was a 1 ton pack so pretty hefty.
    I was chattin with a spring shop, and he said the only thing to be concerned about when pulling the overload is that the reamining spring (the last one) isnt all that short and will do sorta a shitty job supporting, and *may* eventually get stressed.
    Time will tell.
  9. micah
    Sep 18, 2003
    374
    Austin, TX
    My pinion angle is fine... just be sure to move the shackle point forward to match your longer shackle...
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Got any measurements for that?
    How much wheel travel did you end up with?
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Y'all are hilarious, I need to do a write up on that.
    Baddog's idea, I did it first, and now everyone copies.
    I LOVE IT!! /forums/images/graemlins/thumb.gif
  12. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Yea, I am sure you were the first guy on Earth to do that. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Even if not I was the first to post up the pics. /forums/images/graemlins/thumb.gif
  14. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Tim, this is the worst post you have made in a long time.
    Just when I thought you had redeemed yourself /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
    I wish I could remember who it was........ Now that I think about it, I first saw this mod on another board, but that couldn't be possible could it, since you where one of the first to do it /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rotfl.gif
