52" front springs? discussed but can't find
Discussion in 'The Garage' started by sled_dog, Nov 1, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    52\" front springs? discussed but can\'t find
    I'm seriouslly seriouslly thinking about parking the blazer and completely restarting my project again /forums/images/graemlins/tongue.gif. By that I mean coiled rear with 52" front springs. How much lift does a set of 52s give you up front? I'm thinking, stock 52s up front with 2 or 3" drop brackets on front mount.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: 52\" front springs? discussed but can\'t find
    stock 52's up front will net a 4" lift. (give or take a 1/2")
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    The 52's are notorious for cracking, if you want to use 52's, get a custom set made by Alcan Spring. I got a set of custom 49's made by Alcan for my rig, all I had to do was switch around the front mount's and that moves the spring forward 2.125".
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    i put a set of BDS 4" 52's in the front of my 73 and have a little under 8" of front lift and a TON of flex! I just move the front mount foward 2". I also dropped the front spring mount by 2" for a total 9 3/4" total front lift. and I am using a longer shackle on the rear with the stock rear mount. I would also go aftermarket springs. Alot of the trucks I have had, had broken rear springs. Common problem.
