52" in front - Bushings?
Discussion in 'The Garage' started by Art'74, May 11, 2006.
  1. Art'74
    Art'74 1/2 ton status
    Dec 21, 2004
    145
    OKC
    I am putting the rear 52" spring in the front of my '74 K5. As you know, the spring is 3" and the bracket is 3 1/2".
    Where do you get bushings that fit the spring eye and are 3 1/2" wide?
    Mfg. & Part no.s would be great.
    Art
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Most people just use spacers. DIY4x, one of the vendors here sells 1/4" spacers just for that. His website is diy4x.com.
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    +1, That's what I did and they worked GREAT! :thumb:
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I got the spring-eye bushing kits from Offroad Design. The bushings have a 1/2" shoulder on each side and act as a spacer.
    Mike
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    the correct bushings are ones used for aftermarket lift springs (the front eye bushing) Aftermarket lift springs are 2.5" wide so they need to account for the same differance.
  6. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Doesn't that leave a gap in the middle? May not be a problem, just curious.
    I used the DIY4x spacers so mine would have regular bushings, nothing special to buy or remember if I ever have to replace them later on. :wink1:
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    No, it leaves no space. stcok springs are 3" wide + 1/4"+ 1/4" total of
    3 1/2". The aftermarket lift springs (such as tough country) are 2.5" wide, just like stock rear springs. That means they have to make uo that 1/2". so 1/2" bushing on each side = 3 1/2". Nothing hard to remember. Call up your favorite offroad shop and tell em you need bushings for an aftermarket leaf lift spring.
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    im not a fan of spacers... more parts to loose when taken apart and more of a pain to get them all into place when setting the springs in. with bushings it much easier.
  9. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Well spacers in and of themselves sound kinda iffy, but if you're gonna be putting on new shackles... see attached. 3/8" flat stock for the shackle proper and 1/4" for the 'spacer' part at the bottom, welded on. I may later add some reinforcement between the two, but for now they seem pretty stout.
    -- A
  10. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    That's what Kert @ DIY4x built for me. As for loose spacers, I was going to weld mine to the front hanger also but now that I have B-52's I'll leave them loose for the adjustability.
    79k20350, maybe I'm missing something but it still seems like there would be a gap in the middle of the bushing since you would be using a bushing set for a 2.5" spring on a 3" spring. :thinking:
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Stock rear springs are 2.5" wide.
    Stock front springs are 3" wide.
    Aftermarket front springs are 2.5" wide.
    Take the bushings from an aftermarket front spring and put them on a stock rear spring (depending on year, earlier ones had smaller diameter bushings) and you no longer need spacers.
    67-70 4x4s are another source for these bushings.
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    exactly. the whole reason you need the spacers is because the rear springs are 1/2" narrower than fronts...
  13. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    :doah: :doah:
    I had the widths backwards in my head. :blush: :thumb:
