52 measure??????
Discussion in 'The Garage' started by 85mudbogger, Feb 18, 2007.
  1. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    how do i tell if i have 52s in the rear of my many parts trucks i have what should the measure sittin from center eye to eye this has probly be asked before but im on dial up right now and cant stand it haha also is there any benefit if i have longer ones than 52s in the front if i only have 56s or whatever just tryin to utilize what i got already and not spend spend spend
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Measurement is from eye to eye straight across
  3. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    well as far as I know chevys came with 52s, 56s, and 64s in the rear over the last 30 years or so. So if your measure ment is close to 52 then there you have it. A 56 will have an offset center pin too.
  4. 85mudbogger
    Feb 5, 2007
    226
    missouri
    ok so now if i dont have 52s can i use and longer in the front like a 56 is there any drawbacks or advantages to this.:confused:
  5. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Yes you can use 56" springs in the front as well. Benefit would be that you don't have to move the shackle hanger. Just mount the springs with the long side to the rear.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    search for "52 theads" you'll find a thread that has most of the 52" swap thread links in it, it will help you alot;)
  7. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
  8. 1982blazer
    1982blazer 1/2 ton status
    May 11, 2006
    313
    Tyler Texas
    Does anyone else have any links like this one that has a ton of info on one topic?
