52" military tires on D60 & 14B
Discussion in 'The Garage' started by jstevenj, Apr 15, 2003.
  1. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    52\" military tires on D60 & 14B
    Anyone out there running 52" Goodyear tires on Dana 60 & 14bolt axles. I have detroit in rear & ARB in front with 35 spline stubs. 4.56 gears - probably to fast. Will they hold up?
  2. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    Re: 52\" military tires on D60 & 14B
    52"s?? what kind the michilens?
  3. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    4.56gears? you'll be needing some 5.13's for that much meat
  4. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    *Snappy Snappy*
  5. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    52" tires are some heavy mo-fos. A d60 might be able to handle it... but if it was me I'd run some beefy ujoints (CTMs or Ox or whatever) and maybe even some after market chrome-moly shafts (warn prolly makes em for the d60). Then just hope your ring gear doesnt explode...
    i think the most sane option would be to swap in 2.5t axles if you really wanna run 52s.
    j
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I second the Rockwell 2.5 ton axle. They have the diff bottoms out now that actually give more ground clearance than a D60.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the 4.56's won't work and 5.13's won't do much good either.
    rockwells or 404's would be able to help offset that kind of tire.
    Rockwells (6.72) would = ~2880 RPM's at 65 MPH
    404's (7.56, IIRC) = ~3100 RPM's at 65 MPH\
    not sure why you would drive it on the street, but there are the numbers.
    It would also take a crap load of reduction to get those to spin effectively.
  8. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Ox is no longer in business.
    Warn doesn't make shafts for a D60. Only CTM and Sandy Cone. There might be others, but they are probably not as quality.
    No way in hell a D60 and 14 bolt would stand up to a 330 lb. tire/wheel combo, unless you are stepping up from two 10 bolts and 44's. If you are, you need to let me in on your secret to making a shitty drivetrian live under huge tires. Several people have broke rockwells with the 53's. Rockwell shafts are only 1.61" in diameter. 35 Spline D60 stuff is 1.5". You do the math.
