52" rear spring ?
Discussion in 'The Garage' started by rerun93, Dec 28, 2004.
  1. rerun93
    rerun93 Registered Member
    Dec 3, 2004
    98
    chico, ca
    i just wanted tomake sure that if i do the 4" shackle flip kick i can run just stock springs and have a 4" lift. right now i have blocks but they only look like 3 inch and springs not sure how many springs are in a stock pack. so basically ifthose shackle flip will work for me i need to see if anyone has any good stock springs for sale or what year would be a good ones to get. mine are old and weak as soon as i hook up a trailer my ass drops extremely bad and the trailer is empty lol.
    ty
    ReRuN
  2. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    you could always go with an aftermarket lift spring, just an add-a-leaf, or and ORD zero-rate.
  3. rerun93
    Dec 3, 2004
    98
    chico, ca
    true but even with a adda leaf my butt will sage with a trailer really bad same with zero rate. so i think iam gonna go with the shackle flip just curious now on what stock to run. like what years and vechelis to look at while iam at a junk yard. iam guessing the newer the better less chance orf a spring being weak.
  4. goldwing2000
    goldwing2000 Guest
    You could always have a reputable spring shop rebuild your spring pack and re-arc them to compensate for any sag. That's what I'm planning on doing. I've got one busted leaf and 4" blocks that I'm going to replace with a shackle flip.
  5. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    ypu could put a set of 3/4 ton rear springs in it
  6. rerun93
    Dec 3, 2004
    98
    chico, ca
    if i put 3/4 ton springs in it. is the same lenght just another spring in the pack? or just stiffer?
  7. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    3/4 tons had 52" or 56" the set i have laying around has 8 leaves. usually 1/2 ton 52's have 5. you could get a set of 8 leaf and do a litle trial and error by removing leaves till you get the right ride height. :dunno:
